lonewolf
22 -
Hi all looking for a new helmet I currently have an old hebo & thinking of treating myself to a new lid. I run an airoh wheen riding mx so been looking at them for a trials helmet as I know what you get but also been looking at a shiro but havnt seen any report on them. They are a lot cheaper than airoh just wondering if the quality is OK, weight wise they are both the same. Any other options woukd be considered
Pilot cleaned & also the small passage in the body cleaned out.
Pilot jets are all clean & blown out. Funny thing is it runs just the same. When you rev it revs come back down nice & steady. Nothing really changes when you screw it out when it's ticking over revs don't increase. I ran it on sat all the way in & 1.5 out & didn't really notice any thing different between the settings. Temp was around 5 degress C.
Beta evo 250 recently cleaned carb & runs fine only issue is I noticed the air screw is all the way in. Will this be fine. I screwed it out 1.5 turns & it made it run a little worse.
Ah I get it now. I thought looking at the shape of it from website shops it went all the way down into the box. Thanks for that.
With that preformed sheath stuff does it go down to the large box part. If it does how do you get the old stuff out.
I seen that you can get a preformed one but it looks like it does the large part too not just the end.
Hi I'm wanting to repack my evo 250 silencer do you have to do the large box just after where header goes in or do you just do the straight part up before the plastic end cap
Hi I think the problem is solved. Started engine ran for 5 mins, bridged the connector for thermo switch. Fan came on. So was looking like thermo switch goosed. Plugged connectors back in fan then came on by itself. Looks like dodgy connectors. Cleaned them up as best as I could & gonna use dielectric grease on them. Cheers for all your help.
Hi again Right this is what I've done so far I can't start bike at moment as carb is off waiting for an idle screw(shop sent wrong one so taking longer than expected). I've disconnected the fan connectors & put a 12v power supply to the fan & it comes on. So the next port of call when carb is on & bike is running do the same again but bridge the fan switch connector & that should confirm that the wiring is correct. Then if that's the case it looks like the thermo switch in the rad is this correct?
Thanks for your help on this matter miles clearer now. I'll try jump the thermo switch over the weekend. I'll let yous know my findings. Any wire should be good to jump the switch yeah.
Where do I bridge the fan. I'm terrible with electrics.
I had the bike for about a month now & very happy with it I have noticed though that the fan hasn't come on yet. I've been out about 5 times in fairly chilly weather but the fan has yet to come on. Any ideas is this normal for a beta.
To remove the bash gaurd or not to remove that is the questio
lonewolf replied to lonewolf's topic in General Trials Talk
Yeah I'm thinking that can't be done with the faff -
Hi just drained the oil on my 14 beta evo I've noticed some of the oil caught the bash gaurd & has gone over the engine casing between the bash gaurd & engine. Now do I let my ocd get the better of me & take the bash gaurd off to clean up the oil or do I just put the drain bolt back in clean up what I can & bite my lip & refill with oil & go riding. Heard some bad stories about bash gaurds being a mare to fit.
