ohno
21 -
Need info on amount of oil, and weight of oil.
With or without air cleaner in same. reeds? can I start bike with a I.V. by pass pet cock? I just wanna ride.
Yes on switch,have removed gas cap, does it cold have not run it long enough to get hot.
But what on the bike? It over flow right at start up, and the needle and seat should stop any over flow issue. What throws me off is I can put the carb on another bike and the carb doesn't over flow.
O.K> I,m at work and can get on internet. I can take a carb off a good running 4t, with out an over flow issue put it on my bike it over flows. My bike runs great with any of the three carbs that I have,but they all over flow. Only work done was 300 kit. At first bike would start then die. thats why I started re-checking the work that was done everything looks good so I started changing carbs.
I've been told that you need to rotate the engine to do the valves. I need the spec.s
Why? I did not know there were long winters in Holland.
Does anyone out there know the clearance spec for an 2008 Beta Rev 4T? It is time to adjust the valves and I can not find the clearance specification. I have also noticed that when low on fuel in the tank the bike may suddenly stall. As soon as I top the tank up this glitch goes away. Anybody else notice that?
looks like the ex is touching, time to use the phone.
Like to find out if it's an issue before I use that phone! This is the only one he's seen also, I'm hoping riders on this forum have seen more than just this one bike.
Just recieved my Rev4! haven't even rode it yet. What I noticed was the rear ex. hanger sits in the mount crooked, and the rubber groument is not centered. The muffler also sit out away from the rear wheel at least a few inches. Is this normal? did I get an exhaust system that wasn't welded correctly thanks for any input my dealer is 800 miles away.
Thank you thank you thank you I'm going to take a measurement before I start to see how far off the factory is. let you know latter.
Good info I agree I'll do this and let you know what happens on a 07
