			Assgas
				Posts52
| The recent visitors block is disabled and is not being shown to other users. |
	My bike does not ping anymore at mid throttle and it revs clean all the way threw the RPM range and over rev I let a Vertigo rider try it He gave it a two thumbs up. It runs like my EFI
	I just bought a Smart Carb now it runs like EFI perfect
	You can cut it down on a lathe or get the correct insert . I went threw this. You can contact Jack's cycles in Maine USA he will sell you the right one
	Send it back you have the wrong insert .They gave that to me also .A long sparkplug will not fit you need this one.
	Remove the boot of the plug wire and see if there is spark at the wire Disconnect kill button
	Im old and lazy I just like other opinions from people . Brakes don't lock up with the slightest touch anymore.
	Zeta part numbers clutch ZE-3185 brake ZE41-3185
	I found these Zeta levers The wife and I love these very adjustable they spring forwards to avoid braking them the machine work are excellent Do research on were to buy them https://shopotam.com/en/p-zeta-pivot-cp-ze42-3185-ajp-trial-gg-short-clutch-lever-V153318988?srsltid=AfmBOopFwUsPdpIiR9qdfZp4BF0qEIQ1IVyiNosYHM0JRCdNHYvmDZaE
	Assgas started following Rejet Carburetor on a 300 R and Heavy clutch
	I have found that the TRS uses the same clutch plates and Belville spring as Gasgas I took the belville spring and made it thinner and it made a huge difference now its smooth like my old Gasgas
	This will take a crap if you pop the clutch to turn off the motor . It's a one way bearing it does not like going backwards . Pull the lanyard to turn it off
	Yes I know about how to jet. What I really asking is there a needle that works better than the standard one. Some riders really like .
	I would like to change needle on my 21 300 R It seems to be lean 1/4 to 1/2 throttle any recommended jetting and needles
	I grooved the pads I will see how they do this weekend
	I had a 08 GasGas I hated that bike Brakes and clutch were like a light switch on off My wife has a Vertigo the clutch and brake are smooth
