apriljo
29 -
If your garage is like mine it’s got sawzall, grinders, etc for anyone with access to use. Lock your garage, put up cameras and take out insurance on the bike. Everything else is up to fate.
If you’re competing there are usually rules. Page 8: https://www.acu.org.uk/Uploaded/1/Documents/2023 Library/Trials-Standing-Regulations-2022-v5-2112.pdf
The clutch is your friend. Try keeping that lever close to the bar as you learn how the bike moves and how to react with your body on the bike. As you get more used to the bike and finding your body position you can let it out more and more until you can practice with the lever out. Saved me from quite a few whiskey throttles when I was first learning.
No charge to use our property, just a waiver to sign. In fact, we’ve spent thousands on equipment (chainsaws, weed whackers) to clear sections and trails and often buy lunch for volunteers at work parties.
You’re not missing much. The 23+ are easier to start (note: still not trivial to start) and has a bendy fender that looks real nice. If you know the trick to starting a GasGas it’s not a deal breaker. As bendy as they are, I’ve broken way more fenders with the 2023 than I ever did on my 2021. I’m doing more advanced stuff though. They seem to have a weak point where it meets the airbox and the plastic pins just shear off like it’s nothing. I’d consider grinding the next one down so there’s less stress with a fender impact, but my current duct taped fender is doing just fine at it so far. 😆 The difference in pegs and frame are personal preference. If it bugs you, maybe it’s a reason to upgrade 🤷♀️ Personally, I got held up in the shiny bendy fender hype and really enjoy it being easier to start. I like the look of the new model years better too.
Glad you got it in time.
Why I'm considering not going to Trials Comps.
apriljo replied to bikerpet's topic in General Trials Talk
We’ve had our property open for trials riders for a couple years now, all we’ve asked is for an introductory ride so we can get to know you and a signed waiver. I can count on one hand the amount of return visitors we have outside of events and there’s only 2 regulars. We are an hour plus away from most of the “local” riders. I think the reality is that you need the competition events to get riders to make time in their busy schedules to come together and ride. We held our first competition this year in early September. We were lucky enough to have some experienced people come and help us with the section setting. I learned that it takes WAY more effort than you’d imagine to run an event like this. I also learned that everyone has different opinions about how difficult the lines should be, and they often contradict themselves! Ultimately as a section setter I hope to find the balance that makes it challenging but not too difficult. We can’t please everyone as section setters, and I think that will be a consistent problem with other styles of events. -
I taught a friend to start my bike and after pulling the bike backwards he was moving the kickstart until he felt resistance before kicking. It won’t work if you do this since you’ll be turning the engine out of the sweet spot. There’s a bit of easy resistance at the start of the kick when you do it with the trick and you want to kick through it. i agree with Captain Bob. You should bring the bike to the dealer and have them start it. It’s a lot harder to ignore a customer standing in the store with their new bike in tow claiming they were sold a lemon than it is to ignore a phone call.
Pretty sure my wife and I would both have brain injuries by now if we wore half helmets in trials. The extra coverage helps.
I’m finishing up my third year of riding and one of the things I’ve found is there’s no replacement for seat time. Riding with others helps a lot, countless hours of YouTube helps too even though there’s no real feedback or ways to ask questions. Ultimately it’s practice practice practice. Like any sport you need to continue to practice the basics. Balance and body position is going to help with those hill climbs. Practice the things you find difficult too. For me right now that’s off camber downhill to uphill turns. For you it sounds like that’s hill climbs. Start small and work your way up. If you’re an average adult you might need to rev the snot out of that 125 and use your clutch to moderate your speed. It does sound like you might be under biked for your weight. I think most average weight adults probably start on a 200 or a 250. Any bike should be capable and get you learning and enjoying trials though.
2021 TXT 280 , fly wheel weight to soften power delivery ?
apriljo replied to cadarnvice's topic in Gas Gas
In my experience most (not all) people giving advice just assume all bikes are like theirs. I wish! Working today. I'm taking donations to help with my retirement plan. 🤣 -
Choke on. Put the bike in gear and pull the bike backwards. This movement will put the motor in the perfect spot to start the bike. Pull the clutch in, front brake on hard, 1/8" turn on the throttle and give it a solid kick. If it doesn't start, repeat the process from the start. The bike will start in 1 or 2 kicks. People will tell you it's harder to start like this because you have it in gear. But my wimpy ass can start my 300 no problem using this technique and without it I'd be kicking for days. If it bothers you then you can put it in neutral before kicking, but it's an unnecessary step and you risk moving the motor out of that sweet perfect spot. Edit: I've been told in the past this puts the motor in bottom dead center instead of top dead center. I'm not sure if that's the case, I just know it works every time.
When I had the 280 I dropped a tooth on the front and rode up a gear a lot. Eventually you'll get used to people telling you that you're riding in the wrong gear for things (how would they know about your specific gearing?) and you'll miss the pep when you try other bikes. As you've noticed, the 280 is particularly peppy compared to the 300. I think like others have said the main cause is likely the flywheel. -
apriljo started following 2023 aftermarket parts
Any manufacturers making aftermarket parts for the 2023 TXT bikes yet? It would be nice to have an alternative option to GasGas parts for things like pegs and mudguards (yes, it breaks).
It was a great day to see everyone having a fun time riding the sections. The rocks got a little slick with the rain but they dried up quickly. Even though it boosted scores, the rain brought a nice break from the heat. Looking forward to hosting our second event in the future.
