Twinshockwobbler
  1. Hi all, just a bit more info that might help you all out with dragging clutches. As you are aware if you read my other posts, I fitted an Aprilia TX311 clutch hub to my 83 TL320. That along with the 12mm ball bearing conversion did make a huge difference. However, I recently came across a new steel internal clutch arm (the one with the kit is cast aluminium and difficult to extend) which I extended by 10mm, this again made the clutch pull a tad lighter. when riding the bike in practice or events I noticed the clutch developed a bit of drag, not enough to stall the bike but enough to make finding neutral a pain while waiting in turn at a section. I initially thought this is the plates sticking because when roughed up it seems to cure it. I obtained some new steel plates from motoswm as Martin sells the type with dimples that retain the oil better and built the stack up to the correct Aprilia spec. When I put it all together something just didn’t seem right, I’d not changed anything other than the plates but it appeared that the stack was very snug in the basket depth wise, almost not enough room for the friction plates to move about. I tried the bike and it just stalled and even when I got it going the clutch just wouldn’t clear???? I pulled it apart again and got hold of the Aprilia basket I bought with the hub. I’d been using the SWM basket as they are identical or so I thought, I measured the depth of friction plates slots in both baskets, the SWM basket came up at 29mm and the Aprilia 31mm. I fitted the Aprilia basket and reduced the stack height to a fraction just under the spec buy fitting one or two of the older plates, put it all back together and tried it….no drag, no stall, ok let’s try it out in practice. Rode it for four hours in practice which is probably more than you would in an event as your not stopping so much and had no issues at all, was as easy to find neutral at the end as it was at the start. hopefully this is an end to the SWM clutch woes oh and I use 80w oil to. Not sure if this will help out but worth a look next time you’re in the motor. I’ve attached a couple of pics showing the difference in hubs.
  2. Twinshockwobbler posted a topic in SWM
    Hi all. Right I’m going to throw a grenade in here on this subject. Stock jetting is pilot 60, main 90 X2 needle and 70 slide, this we all mainly know. Right here comes the grenade. I’m running 52 pilot and 85 main to get my plug looking anything like how it should, I’ve gone right through the carb, float needle, float height, new needle, new atomiser, new choke plunger. On stock jetting the bike simply over fuels and the consumption is quite high. We’ve had this problem with another SWM and also a TX311 and in both cases the problem is solved by leaning the jetting. All the bikes pick up a lot better and do rev out ok. A 70 slide is lean and I believe by using a 60/90 set up and in some cases 65/95 we are mistaking poor pick up and rev out on under fuelling when in fact it’s possibly the opposite. All bikes from new tend to be jetted a bit on the rich side to prevent nip ups and warranty claims but I feel you’ve got to really experiment in this area and especially so with a trials bike. I’m not saying my set up will work on your bike but a little tweeking can reap rewards. I now find the pilot /needle circuit to be quite precise and you don’t have to clear the engines throat due to over fuelling. should add were 200-600m above sea level.Let the abuse begin 😂
  3. Hi Jimg, so sorry for a slow response to your questions. firstly my bike isn’t a jumbo, it’s an 83 TL320. Rest assured the shorter springs won’t cause slip on your 350. At the end of the day both 240,280 and 350 are downrated mx engines that would need the strong springs for that application and furthermore theyd be clutch less shifted so a heavy clutch wouldn’t be noticeable. I think 340mm is the stock shock length but I run rockshocks 360mm with no noticeable difference, if anything you gain a tad more travel when the bike is weighted. I also swapped the well tired fork springs for a pair from REH, a hard one in one leg and a medium in the other, they are shorter than the originals by about 20mm but a longer spacer solves this. As long as the springs are longer than the travel your fine. I recently rebuilt the engine and fitted a clutch hub off an Aprilia TX311, this has the last plate as part of the casting so uses one driven plate less than the SWM clutch and has a far superior actuator bearing. I get no drag at all with this set up even if the bike is stood for a while. If you go down this route just make sure you get the 3mm thrust washer that fits under the splined tab washer, the SWM uses a 1.5mm thrust washer with the standard set up. Hope there’s some useful info for you all.
  4. Hi Iconic, yes your right about lever selection. Even Domino levers have their differences. I’ve just fitted a Domino lever blade with a pivot to nipple centre of 24mm and the difference in pull again is huge , the lever blade I took off it was 30mm. I suppose manufacturers bulk buy to a price so some bikes may have had these 30mm levers for that reason.Amal levers also do a 24mm pivot and their a nice lever but they need to be pulled almost back to the bars to clear all the drag. Other than maybe experimenting with different clutch springs, I don’t think I can improve on what I’ve now got other than finding a txr or climber outer case but if I’m honest I don’t think I’m that far off that level of lightnesses now, my son’s bike has the txr set up and it’s not much lighter
  5. Hi all, new on here but have been looking at the thorny subject of SWM clutch upgrades on the TL models. after pulling the clutch to bits several times and not being able to improve the standard set up i by chance got talking to Gary at Sportax Racing, he was able to supply the Aprilia type kit with 12mm ball bearings and also some standards generic to all motors, standards clutch springs. The springs are lighter than the 37mm ones fitted and also shorter at 33mm. The difference is massively noticeable ( just about one very strong finger😁). Apparently the 37mm springs are classed as heavy duty and due to their bulk when compressed, they can foul on the basket and posts. I also noted that on some of the friction plates, the material fouled the slots in the basket causing drag. This is easily cured with a bit of filing. The clutch is now drag free and far better to use, the 12mm ball kit also can be used on the 350 Jumbo and early fourstroke motors as well. Hope my first post on here is helpful. Oh and always use genuine Rotax crank seals,you really have to press them in compared to the push fit of some aftermarket ones👍 https://sportaxracing.co.uk/shop/clutch-kickstart/item-12-spring-239-625/
