Donaldw
    5
  1. Thanks for that, I will start to get everything tested 👍
  2. Hi Last time I was out on my txt 300 noticed some smoke coming from below tank, had a look and most wires for the fan were melted and charred. On Futher inspection I saw the thermostat module/rectifier/ regulator (saw it called a few things had basically melted . Are there any specific causes for this or should I just start replacing parts. Thanks in advance just looking for some knowledge.
  3. I'll give everything you mentioned a check and clean also I've ordered a service kit for carb with a slide so will fit that and take it from there. Thanks 👍
  4. Hi You have probably heard this before but my 2003 txt pro 300 is starting, running and riding ok but every now and again usually at the wrong moment the throttle sticks, a quick blip of the throttle usually clears it. The cable doesn't seem to be snagging on anything, only thing I have noticed is I took the slide out and it is worn an both corners of the rounded side. Will this be causing the sticky throttle. Thanks in advance if anyone has any ideas.
