scorpaian
15 -
why put that diagram up? I think the majority of people know what I mean. What's up with people on forums? End of subject now!
Tr1al I've got a good anodised head insert with long plug and orange champion suppressor cap. The tank fits no probs, v difficult to remove suppressor cap though, I have done it but not easy. I ended up lifting tank up to re fit. I think I'll just use normal NGK long reach plugs! The bike works great as it is, so "if it ain't broke" don't fix it!! :-)
so, I've got to stick with the gold head with long plug.
Yes I've seen the splatshop description, it's very confusing but I get it now, basically I need to buy long reach NGK BP6RES plugs!!
Dude, you've missed the point, forget the plugs at mo, it's the insert I'm asking about, I have two short plugs (seems correct small ones) but the one in it is a long reach, why? is my insert different or incorrectly made? Anyone have an answer, I think Konrad seems to get it, but still not overly clear!
hi, yes I have two small plugs, that's not what I was asking bro! Thanks for reply though.
So looking at S3 website, the pics show the neck of insert where I screw in plug a lot shorter than the one I have? Was this a mistake? or just altered and I have an older model insert? So basically, the normal bike should have a small short reach plug, but as my plug head insert is longer it's had to use a normal tall plug?? Only way to use standard short plug is to turn head insert down?
scorpaian started following TRS 300RR plug type
Can anyone advise me what plug is needed for a 300RR fitted with S3 low compression head? A moment it has an ngk bp6 stand long reach plug, is this because of the head insert? The correct plug I seem to keep seeing is a small short reach bpmr6a? Any give me correct info? TIA
I cut off all of the rear shelf bit that connects to airbox, then used numberplate plastic boots pre cut through, with plastic nuts..
