ossabultaco
    4
  1. i have a 1998 cota 315r can anybody tell me what spark plug will make it run its best the book says br6es is this the best plug for it?
  2. hi nigel i have brought some boyesen reeds for my 290 sherco do you recomend to take the stops off and fit the rev plate that came with the reeds the 665 reeds you recomended fits the reed valve block ok thanks for your help john
  3. when we bled my montesa 315r rear brake we took the caliper off but left pipe connected put a piece of metal between brake pads and held caliper so bled nipple was the highest point also it is a good idea to squeeze pipe from reservior to master cylinder to remove air from pipe also you could try just opening bled nipple and letting fluid run through
  4. hi i have a 290 sherco and was thinking of putting different reeds in it has any one done this what was the result ie was it worth doing it has a keihin pwk i have to do this because my brother has a 300 gasgas
