zaa9
15 -
i also snt my 1997 asy stater plate to west country windings, and they re-wound it. i dont know much on this subjct so excuse me if this is a stupid qustion, but cant the pickup coil be re-wound? thanks
Hello. That is the fan rectifyer you have found, i hav rcently wired my 97 easy up. howver i cant recall the wire colours but it sounds about rite. i chose to leave out the temp switch as it started playinng up, the fan now runs constantly. thnaks.
Hi, i broke the gear lever on my 1997 rotax scorpa easy, will this http://cgi.ebay.co.uk/Scorpa-SY-250-Yamaha...%3A1|240%3A1318 from a 2001 bike fit? it looks similar but th splines may be differant? Thanks
Hi, i lost the spark on my scorpa easy 97, with exactly the same problems as you. The stator had gone. The fan uses a differant coil on the stator plate than the ignition, so the fan will spin even if the ignition coil is bust. I had mine rewound for around
Hi mate, mine runs fine on castrol tt oil at 50:1 OR 100ML per 5000ml of super unleaded petrol.
Hi, my easy 97 is running a dream, only problem is that on a hot day it overheats due to the fan not being wired. we have the yellow wire from the stator which produces an ac current, which ranges from 10v at idle and over 200v when revved. been looking for a voltage regulator but can only find a small black box which i don't understand. Here is a link to the picture of the black box BLACK BOX Any help appreciated. Thanks
hi, 1 year ago i got myself a scorpa easy 97, and have had a year of fun. I recently saw an ad for a 2001 scorpa sy250. How is this bike, are parts available, can i buy a long ride tank, and what do i look out for? Lso how much should i be paying? here is a link. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=008 Thanks in advance, Chris
Hi mate, try the hell teams tech info. http://www.scorpaaustralia.com/Tech.html
ITS RUNNING, THANKS FOR ALL YOUR HELP. got the stator back from west country windings, fitted it to the bike, started seccond kick aand runs soooooo smooooooooooth!!!!!!!!!!!!!!! Thanks again for all your help. Chris
hi, just got a puller but, can't take off the big nut, is it anticlockwise to undo or clockwise. Thanks
can Anyone help with the flywheel thread, what size is it? Thanks
thanks. we are going to make a flywheel puller and send the stator off, what size is the thread on the flywheel,. Thanks
The spark has gone again, after we started it we went for a ride, it ran perfect. but the half an hour later it stopped. there is no spark again. if i kick it over with the plug out i occasionally get a spark. could it be a broken wire, i have removed kill switch and replaced ht + spark plug and cap. Thanks
Got it started!!!!, cleaned air filter, drained carb. few kicks, lots of smoke, then it run fine. Thanks for your help. The bike's fan has at some point been disconnected, I have one wire from the motor to the temp switch in the head, but the other wire from the motor is cut and goes nowhere (its blue and black, the other wire from the temp switch is also cut and goes to nowhere (black). Anyone help us wire the fan. Thanks
Hi, my name is chris and i am new to trials. I purchased a 1997 scorpa easy 250, i was out riding and suddenly it stopped. We took out the plug and there was no spark. We took it home and had another look, now there was a spark but it wouldn't run, we replaced the ht leat, cap and plug, bit better spark but still no running. We sent it to the local trials shop , and they checked the woodruff key and it was ok. That left us with the cdi/coil unit, the analouge controller and the stator, we removed the analouge controller but it still wouldn't run. we then priced up the parts. The "rotax man" said the cdi was
