jellybean
    5
  1. Thanks for the info will check it out and let you know how i go on many thanks
  2. BABY MONITER WORKS GREAT I HAVE HAD ONE FITTED AND HIDDEN IN AN ALARM BOX ON THE FRONT OF YHE GARARGE THE RECEIVER IS NEXT TO ME IN BED ,I HAVE HAD TO PUT RECEIVER ON A TIMER FROM MIDNIGHT TILL 5AM OTHER WISE THE TRAFFIC WAKES ME UP BUT YOU CAN HEAR ON IT GREAT .ALLSO BOUGHT A CATTLE PROD OFF EBAY AND IT SENDS 1000V PULSE TO THE DOOR EVERY SECOND IT CONVERTS 12VOLT TO 1000 VOLT BUT VERY LOW AMPS ITS MEANT FOR ANIMAL USE PLUS A LOAD OF OTHER STUFF BRING BACK HANGING ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~
  3. jellybean
    Scorpa Easy 250
    HI MATE CHECK THIS INFO OUT RING THE GUY CALLED ROY HE POSTED ME A PULLER HE MAKES THEM .ALLSO VERY INTRESTING TO TALK TO OVER SCORPA PROBLEMS GOOD LUCK HOPE YOU GET SORTED JELLYBEAN . Ringwood Precision Engineering,Unit 2, Millstream trading Estate,Ringwood Hampshire BH24 3SA, U.K Tel:- 01425 476296. (Roy) On the phone I talked to Roy (Great helpful bloke)who told me that the main ignition coil on the stator plate was a problem on Scorpa's and thats why he made the puller. HA HA now we are getting there. 3.Got put in touch with WEST COUNTRY WINDINGS Unit 79 City Business Park, Somerset Place, Plymouth, Devon, PL3 4BB Tel :- Barry on 017525 60906 They said they could test the stator and fix it if found to be a faulty. So on Monday a.m. I posted the Stator, On Tuesday mid day I had a phone call from Barry saying he had found the fault in the ignition coil, On Wednesday got stator back in morning, fitted it back to the bike (RETARDED AND WITHOUT ANALOG CONTROL)kicked it twice and away she went as smooth as a babys a***.All for
  4. With rotax engine it runs like the choke is on all the time on low revs i have had the carb in bits and adj the needle settings as the revs pick up it runs ok and starts great all the time .could it be the reed valve or a worn needle i can get it to run not bad untill the bike starts moving then awfull again any help please
