andy0101
    41
  • Website URL
    http://www.drivingschoolcrewe.co.uk
  • ICQ
3,662 profile views
  1. how about checking the non return valve is on the vent line and is flowing the correct direction
  2. Hi there i think its Matchlessizm in cheshire cheers it should be a good bike when its finished ,ive never seen one in a pre 65 trial
  3. Hi there im rebuilding a Matchless G250 for trials riding it had a 28mm monoblock carb on as standard road trim what size should i buy a new concentric carb for trialing cheers andyd
  4. hi there Barrow and district mcc and Bootle scramble club use some of the land thats used in the Lakes 2 day , so its good to do a couple of there club trials, to get to know the land first. id be looking at a good clubman or green route rider minimum, it is hard, its renowned for being a bit hard but as Woody said its a national i think il have a go this year
  5. andy0101
    Forks ?
    Hi there Thanks for the replies, the offset is the same on top and bottom yokes they were all bolted together when i got them that top yoke is a casted piece of ally very light , but the botm yoke is heavey cast steel
  6. andy0101
    Forks ?
    Hi there , ive just bought these forks for my Cub , they are 30mm diameter sliders the yokes have a big offset and have the tapered top Does any one know what they were off and how old are they suitable for the pre 65 scottish ?
  7. join Macclesfied trials club on line its free and they will email you with a code for the acu licence
  8. hi there i rode in a trial last weekend ( Macclesfield club) ,they got a good entry of 140 so with no starting order the queues were big ,so big i had to take a photo of this one , thankfully it was on the last section by the way its not a gripe ,i had a great day and a good crack
  9. ive had a 2005 Gas Gas with a michelin tubeless ,i couldnt get it to seal ,tried everything ,i ended up sticking a tube in it ,100% reliable
  10. hi there i just bought a jotagas 300 a couple of weeks ago ,second hand nearly new , i gave it a good service then rode it first in a trial ,it took a lap to get used to it mainly the gearing , i found i could use 3rd in some sections because the power is so smooth , after the trial i never felt tired but felt like i had owned the jotagas for 6 months it gave so much confidence ,by the way i have had a 250 gas gas before this
  11. i have used vee rubber tyres for a year or 2 while getting back in to trials after a 15 year break i found them ok in sections but they dont clear the mud out of the tread very well and the front tyre after 2 years the side wall perished and cracked they are good if on budget but michelins are the best if you want to get serious
  12. tyr a bp5hs if you have problems oiling the plug
  13. yes those bulto s were ace , as were the yam majesty s and the new ossa
  14. thanks il look forward to it , does it start just off the mow cop road plz
