alt
24 -
Hi Chaps,wasn't Eddy Moermann sponsored by Vim Vos when he was riding the 242 Montesa?Cheers,ALT.
The popular mod of the period was to increase capacity to approx 264cc using a Yam IT 250 piston,shorten the inlet tract,can't remember how much and also cut away some of the reed valve petal.I cant remember if any porting work was involved- probably was.I had various tail pipes on mine,ranging from one of Shirty's to a Kato,then a WES "GO" and finished up making my own.I had a spare back wheel with a Talon hub like quite a few people.There must be a few still about.There were various aftermarket carbs on the market at the time all reputed to improve performance.There were some good riders on Yam monos at one time,Scarlett,Alderson,Birkett,Andrews etc.Probably the most exciting rider I saw was young David Page.He was destined to be very good but sadly his premature death ,from I beleive leukaemia,meant this was'nt to be. ALT.
If you have a thicker liner and minimal clearance,you can use standard shoes-no need to machine shoes every time they are replaced.Just my opinion.Incidentally why iron in preference to steel? Cheers,ALT.
Hi Feetupfun,I don't know if you've had steel liners put in the hubs yet but when you do it might be an idea to find someone(a local machinist perhaps)who will machine the liners such that you end up with the absolute minimum clearance between lining and liner.This will help to increase the contact area and also reduce the amount of lever movement.I did this to mine and the results were really good.Cheers,ALT.
OK,thanks Charlie.By the way,are you a pseudonym (dont take it the wrong way!)?Reason for asking is that I don't live a million miles from you and have been riding trials for 31 years,so there's a pretty good chance that I should know you!
Big John,I already own a B40 and I don't plan to enter the 2 day on a cheat Cub,, even if it appears to look "right".Cheat bikes are killing pre-65 trials(my own B40 included),so I can sympathise with your views but can someone answer my question?
What is the maximum engine capacity that can be achieved on a 200(late motor) Cub without increasing the stroke?Anyone have any comments on the no doubt numerous ways of doing it?Cheers,ALT.
Hi Superhondaman,I have a genuine trials swinging arm on my cub but even using that it can problem if you use a normal type chainguard.To get over this I use a tubular type guard similar to what Montesa used to use but only on the top chain run.I made mine using 25mm electrical conduit.It works well.Cheers,ALT.
Hi SwooshDave,yes it contains pretty much the same info.ALT.
Hi SwooshDave,If you just type in John Collins in the search facility provided on this site,you can scroll through his many posts.Thats how I found the info.Hope this helps ,cheers,ALT.
For anyone who's interested I've managed to do it by using Barnett friction plates and taking the trouble to set things up as John Collins suggested in one of his posts.There is no slip and no drag and the "bite" point is in just the right place relative to the position of the clutch lever.I did however need to leave out a friction plate and a drive plate because the Barnett plates are a lot thicker than standard.Cheers ,ALT.
It would be nice to think that someone well known rode it but there are no CD pre-fixes to the frame or engine numbers.The most likely thing,perhaps, is that it was built and used as some kind of test "hack"and then sold off to someone who worked at BSA.Whatever ,it's still a nice thing to own.I will put a close ratio cluster in it,put lights on it and use it as a trail bike.Cheers,Alt.
I have in my possesion a C15 that I bought in bits (and I mean bits!).I obtained it from an ex BSA employee.The bike had passed through the hands of a number BSA employees before him.The chap I bought it off trialed it in the early to mid sixties.However,he used to ride it to work and whilst doing so had an altercation with a car which resulted in,amongst other things,a bent frame.This of course required a strip down for repairs and while the engine was out it was completely dismantled,Alpha Bearings did the crank in readiness for the rebuild.The frame repair didn't go well however and because of this he lost interest and never rebuilt the motor.Basically the bike stayed in a million bits until I bought it four or five years ago.I've since nearly finished it.Now for the interesting bit,if anybody is still reading this!When I went to see the pile of bits I was under the impression that I was going to see a C15T.It turned out to be a C15S.(Yes I'm aware that the trials frame had an S pre-fix).The motor is a scrambles unit ,C15S pre-fix,it has a scrambles big valve head and cam but had a trials gear cluster!Must have been interesting in the sections! I have the old buff logbook which shows that the BSA factory was the first registered keeper and that it duly passed through BSA employees hands.The chap I bought it off could shed no light on things. Why would the Factory road register a scrambler and why would a scrambles motor be fitted with trials gears?Any thoughts?
When I said Beamish I meant Fantic!Any more ideas on getting a lighter clutch?
To reply to Big John's post:I don't have enough talent in my right wrist to ride without using the clutch!In any case old habits die hard,I've been riding "on the clutch" since I had my first Bult in 1982.My Dad tried hard to persuade me not to!Incidentally,I recall the first time I saw anybody hopping the front wheel whilst using one finger on the clutch-a certain Mr Saunders,at a Stratford trial at Camp.He had just swopped from a 250 to a 340.I remember Wrighty trying to do the same on his 325 Beamish-without success!
