fantic303
    182
1 Follower
  • Website URL
    http://www.fantic.nl
  • ICQ
8,500 profile views
  1. Manual says 1.35kg of 2.97pounds SAE30
  2. Hi Ludde, nice to read something new from you, can you contact me by mail because the e-mailadres i have from you doesn’t work (anders.ludvigsson@comhem.se)
    regards,
    Bas (sw.zeinstra@quicknet.nl)
  3. Remove the clutch cover and pressure-plate. Push the rod, the small push rod with O-ring will come out on the other side. normally it is always possible to get the small rod out without removing clutch cover. Perhaps you are missing the ball between the two rods.
  4. I think you are missing the o-ring
  5. Bienvenue Claude. La langue française ... pas de problème.
  6. This is what i have made from a piece of 22mm central heating pipe
  7. The interface looks the same but internally different, it is not possible to use it for the 4RT or 300rr
  8. On the intake manifold. Take a look at the partslist, everything you want to know is there
  9. http://montesatrials.com.au/store/category/model/
  10. a possibility is https://www.123roulement.com/roulement-SAC2647-1-KOYO.php or https://www.123roulement.com/roulement-SF0581PX1-NTN.php ground the innerring to 9mm hight and you have a real copy of the original one.
  11. Look here : https://www.bearingstation.co.uk/products/Bearings/Bushes or https://simplybearings.co.uk/shop/Products-Wrapped-Steel-Plain-Bushes/c4747_4531/index.html
  12. More to read Cota 4RT Full Power Version removal of the restrictions
  13. Bearing dimensions for the 303 headstock : 2x 20 x 43 x 13.25 https://www.123roulement.com/roulement-639177.php
