Hi. Our boy's Beta 80 (2014 b/w) starts and runs sweet from cold, but as it warms up, it's as though it's retarding. It feels tight like it's going to seize, has no power off the bottom, and sounds a bit rough. It revs out though. Fast 'blipping' of the throttle in neutral fails ("bwoooor"). Slightly slower blipping is fine, but it's like it can't wait to get back to tick over (i.e. no run-on of the revs). Leave it overnight, and the next day it's fine for 5 minutes, then same again. We have tried re-positioning the CDI to get it away from the direct heat of the cylinder / exhaust. No change. We have tried a brand new CDI. No change (no change in fact out £180!!). All manner of experiments have been made with regard to carburetor jets / needle / mixture screw, and fuel / air supply is all fine. We don't want to give up on it, because it is clearly capable of running ok, like when it's cold, but there are times when I want to dig a deep hole and bury it. Is there something that should be (but isn't) telling the CDI to alter the timing when hot? We have a 2018 s/w Beta 80 and apart from occasional touchy carb settings this generally runs well and as expected. Any help / guidance gratefully received. Thanks.
