jezzyb
12 -
try cleaning out the carb , my easy was like this it was the slow running jet, cleaned it out and it ran like a dream for the tech info go to http://www.thehellteam.com.au/
my mates aprillia 280 climber stopped working after he changed the oil, he had the bike on its side while drilling a hole in the bash plate, after that it wouldnt start, i cleaned out the carb it fired up eventually but run like dog, the spark is very weak , i have a scorpa easy and i had problems with the stator is the aprillia prone to stator problems? has anybody had any similar problems or any advice thankyou jez
How doo a 1999 scorpa easy 250cc was sold on e bay a couple of days ago for
just a update on my easy problem, I left the timing in the central position gave the carb a good clean and it appears to have solved the problem its running a lot better thankyou kind people for your replys well appreciated jez
thanks for that dan got in touch with the company who rewound the stator and they said the wires from the stator might need reversing so you dont think its the carb i dont think it is but i have to check how do i check the timing thankyou jez
just had my stator rewound on my 99 easy the bike fired up first kick however i have lost the bottom end revs , its just not right when you are at tickover and want some power , it hesitates and you have to keep blipping the throttle or it will stall i have tried moving the stator plate and its better when its retarded but will only then start with the choke it looks like it could be the carb but having the stator repaired i am thinking they may be a problem anybody shed any light on the problem or anybody know any carb settings also i have been told you dont need the analogue box under the seat but surely its there for a reason thankyou jez
How doo i have a 1999 scorpa easy dont know if its 25cc or 280cc i have tried to find the differance but no joy. had my scorpa about 3 months and the stator packed up , this seems a regular fault with the easy model, it loses its spark then the next day it will fire up . i have just had it re wound at west country windings
hI can anybody let me know if the flywheel nut on a scorpa easy 1999 is left hand or right hand thread also whats the correct socket size my 27mm feels a bit slack thankyou jez
Thanks chris the bike started first kick the other day however i have ordered a puller for the flywheel as this as happened before and called in at my local bike shop and he said the same as you and he will send off the stator for testing for a fiver . ( thought that was very reasonable ) can you remember if the nut ( flywheel nut) is left hand or right hand i tried this morning to slacken it but it was very tight thanks jez
Riding my 1999 scorpa easy yesterday and it kept stopping, It started up again no problem this happened 6 or 7 times, then it died , not to start again, no spark i checked all connections etc changed plug no joy,checked cap and lead . I joined the wires from the temp sender and noticed when i kicked it over that the fan was starting to spin so i am guessing that the stator is generating power. Can anybody recommend the next step ? Can i test the black box under the tank and what is that analogue thing under seat I can see the pounds mounting up if i just start throwing bits at it hope anybody can point me in the right direction thankyou jezzyb
Hi everybody been out of trials for a lot of years and just got myself a scorpa easy 1999 very impressed , However i am unsure of the engine size was told it is a 250cc when i bought it but i have seen 1999 scorpa easy advertised at 280cc can anybody tell me the engine size is there any markings etc thankyou jezzyb
How doo just got back into trials riding i am 47 not had a trials bike for 30 yrs (old git) i used to have a greaves with a villiers engine what a differenece just got a scorpa easy totally different to the old bultacos and ossas however yesteray my beloved scorpa easy packed up no points to mess with couldnt even bump it off long push back to the van gasp gasp bones aching ankle sore bad back love it bring it on thumbs up to trials riding nice one jez
