markt
17 -
is this a beta if so put a domed head allan bolt where the cleaves pin is
yes you will have to take plug out check piston at top
yes get it on tdc if valves are tight you maybe a revalotion out so turn it over carefully till the T mark comes around the next time you should now be set to check
so what bike you on about you have a 200 what
hi all there is a head spacer avaliable for the pro give BVM a call
BVM STOCK THEM IF YOU SPEAK TO LAURANCE HE WILL SORT YOU OUT
hi yes got one on my 4rt really good shock and you can get different springs
hi central wheels birmingham send them by post and they will return once done by post
hi try saunders extrem sports web site he has many bits
IF ITS THE SHOCK THAT'S HAD IT TRP DO A REPLACEMENT AND THEY ARE A REALLY GOOD SHOCK AND MAYBE CHEAPER THAN STANDARD ONE. PLUS THEY DO A SPRING TO YOUR WEIGHT GIVE BVM A CALL THEY WILL SORT YOU OUT
HI I WOULD CHECK BOTH TOP AND BOTTOM BOLTS ARE TIGHT FIRST
having the choke on makes your bike run richer to help prevent your bike running to weak and seizing. not to make the bike faster at all
HI THAT BIT YOU HAVE BEEN ADJUSTING IF YOU LOOK UP THE CENTRE OF THE PART WITH THE SPRING AROUND WHILST MOVING THE GEAR LEVER UP AND DOWN IF THE CENTRE BIT MOVES ON ITS OWN YOU ARE LUCKY JUST REPLACE THAT PART GOOD LUCK
