daveg
17 -
hi,thanks for your help been in touch with c&d autos v.v.helpful will use again if i need parts for bsa's highly recommended.now all i need is a angle grinder and big hammer.cheers
hi,fitted smaller front engine sprocket and electrex ignition tighened up,engine dosnt turn primary chain fouls case,what do i need to do remove shoulder where chain fouls or ????????
thanks for all the info.going to use road gears for now any suggestions for gearing down.cheers dave
hi charlie thanks for that will let you know how i get on was thinking of putting it in oif.frame b25.cheers dave
hi guys.thanks for all that info.charlie what do you mean by narrowing frame.also no numbers in ussual place under barrell drive side and it dosnt look as though numbers ground off.im not sure about timing side bush conversion as i ran a 500 triumph for years with plain bush and gave it some welly but changed oil on time.and had no problems.cheers
hi just bought a c15 engine distriputor type.thinking of putting it in oif b25 frame to do a few small club events.going to strip engine to check any usfull suggestions without braking bank.will fit elecronic ignition.cant find engine number.
any idea on size or model. thanks
had suggestions about what carb to fit delorto seems to be the most popular anyone got one fitted and how do the get on with it.or are there any suggestions
thanks guys thats the ignition sorted.next the rear tyre what size tyre and rim fits the sammy miller swinging arm.ive bought a pair of cerinias 32mmm are they better than the oif.b25 forks i was going to fit.also whats the best round or square barrel im confussed.ive just joined a club.dabbers club cambridge still trying to find place to practice,very friendly club not to serious so i dont have to go worring to much about regs as im just a beginner.
hi,just bought a 64 frame 61 engine tank wheels etc.want to make a trials cub.not ultra competive just a few easy trials.got to build up engine any mods to done.should i convert to points on side what sort of ignition(rex gaunt type).carbs.have a set of 69 b25 forks.any good (better than cubs).any suggestions
hi, complely new to this game.i have a b25in need of restoration and was going to do up for road use,and green lane. but after seeing a local trial in norfolk by the dabbers club. iwondered if it would be suitable for a begineer to start on. and what mods would have to be done.ihave allready but a 21" front wheel on it trials pegs ali tank and gaurds. any sugestions or should i buy a trials bike like a c15t.i enjoy working on the bikes and have built other bikes like a triton and have my own lathe etc. any one have ideas?
