Just done the same, stripped it down but it is only sealed by flat face pressure exerted onto a OEM seal, so once it leaks it looks like its a new tap.
All back together now and back on the bike, new tap needed.
I am fitting an S3 front pipe to my sons 125, but I do not have the suggested compressor insert (as recommended by S3) does the insert make much difference?
Also does any know how much effect the S3 pipe will have on the bikes performance, or is it all sales hype?
If you have adjusted the brake lever and not left a small amount of free play the brake fluid can not return to the master cylinder, this will cause the extra heat created during riding to overheat the fluid because the pads do not release correctly. Once the fluid is hot the brake will fade.
I have the 300 4T never normally have a problem with starting when hot but have found that if the bike has been on its side or stalled, a big handful (100% open) will start the bike first kick every time, I do not use the hot start plunger.
I am changing the swinging arm bearings on my sons 2011 evo, has the bearing size been made smaller than the rev ( width of the bearing 2mm smaller) or has the previous owner fitted the wrong bearings.
If anyone knows the definitive bearing number that would be great as I am unable to read the bearing number and can not find the evo bearing number listed anywhere and the rev bearing is listed but is bigger than the bearing in our evo.
Sorry make sure the metallic part of plug is touching the cylinder head or some other metallic part of the bike when testing for a spark. Sorry if that is patronising but some times it is easy to assume someone knows and if they don't we could run round in circles for ever.
Evo Fuel Tap Leak
in Beta
