erixon
22 -
I got mine from lewissport usa. I have put a inline fuelfilter on it. And a reed spacer so it fits really god. It starts in one or two kiks now, but if use the choke it dosen't start. Think i have a jetting problem, the sparkplug was grey white after my first test run on this spec: Pilot 45 Main 120 Needle clip in middle. Today i put a 48 pilot in and lifted the needle max. It seems to be running great on low rews, but the bike don't rew to the skys. so i think something is wrong on high rews. Anyway the sparkplug was black dry today. Do you think a 125 main will do the trick for me ????
I just bought myself a used gasgas 280- 2006. Does anyone know where to connect the cdi swith? I got all electronics in a plastic bag with the bike......
Just got my kehin pwk 28, and installed it on my gasgas 280 - 2006 today. The problem is that the bike wont start. What should i check?. To little fuel or to much ? Float level ?? The carb got two adjustment screws One big black with a spring, and one little gold. Witch one is for idling ?
Well i just sold my 280 Pro 03, that bike was really nice, The differance between this bikes can't be that big....or can it ??
hmmm... Do you think it's to much power for a novice ??
Does anyone know what ignition curve this bike have, is it the same as the 06 300 pro ??
Does anyone know where i can find black excel rims for my gasgas??
It's a 280 pro -03 I'm using dextron atf in the gearbox
My clutch is dragging a bit so I am going to strip it down and check the thickness of the plates. Is it anyone here that can explain how you strip it down....is it hard ?
hello !!! I'm about to put back my clutch cover on my bike, 280 - 03. And i found a washer on the floor.... i know that it belongs on the kick axel, but i don't know if it's inside the clutch cover or outside of the clutch cover behind the kickstart pedal base ? Does anyone know ?????
Having some problem with clutch drag on my gasgas 280 -03. And i need som help explaining how you bleed it, and what fluid you use in it ?
I'm about to change the fork oil for the first time, and got some questions There's a little screw in the bottom of the fork, is that for draining the oil ?? When the oil is drained, must i open the large nut at the top of the fork leg or what ??? The bike is a 280 - 2003 Best regards Christian
Hi I have a gasgas 280 -03 and have a question about the fan, i don't know if this is normal, but when i use my bike the fan starts really often....15 sec after it stops, it starts again....this is when i drive my bike really slowly, but do you think it's normal ?? The bike has been used for about 20 hours.... Is this normal? if not, what can be wrong ??
I'm about to setting the sag on my gasgas 280 -03...and have some questions..... My weight is 62kg Is that a good weight for the standard springs ? My front suspension works great and i have 1/6 sag on it... To get the rear sag i have to use alot of preload on the spring....i only have 1/2 inch left to the bottom of the threads on the shock..... Is that bad in any way ?? Best regards Christian
How much travel do i have, front and rear on my 280 PRO -03 ??
