b40rt
    6,076
Posts posted by b40rt
  1. My totally biased opinion obviously - SWM 320
    PROS- grips better than anything i have ridden (i have ridden many bikes)
    very well built, very reliable , tons of torquey usable power -but not too powerful
    parts still readily available
    CONS- a bit heavy than some , but this helps with the grip
    this is obviously going to get some replies!! but its my opinion! everybody has their
    favorite/opinion. ;)
    Got to agree with you, dont remember it being to heavy, 280 was the best engine. Had to run it a bit rich to get it to grip.
  2. Regarding the waterpump casing rot, i checked mine out in the weekend, and found that it was starting to corode inside. I was told to paint over it(if its not too bad) with epoxy by our local beta importer. What i decided was to do was paint it with nail polish, cause i was in a bit of a hurry to ride, and i had no epoxy.
    Now im stressing about it, thinking maybe i made a mistake. Do you think the nail polish is gonna hold up?
    What colour
  3. I was given it and seems like a good idea to support the shaft. I know that they are properly used for scrambles and not really needed for trials? Just trying to make an half decent engine after finding lots of little proplems with it.
    Would you not bother with it?
    I dont claim to be an expert but my WD B40 (without tempting fate & touching wood) has been pretty reliable without this. So if its giving problems fitting it I wouldnt bother.
    Anybody else got experience of this ?
  4. Hi this may help, Not really sure of the electrics on bsa's but you can test by using a multi meter set for ohms, testing each of the wires with each other. you should have some resistance and no open circuits. you can also test with a meter set to volts DC testing from each wire to your frame as negative and kick the bike over you should see the meter read 6v or around 12v.
    I hope this is of some use
    Thanks for the info, will give a try.
    Ross
