b40rt
    6,076
Posts posted by b40rt
  1. Longer shocks would not raise the gearing as the spatial relationsip between terra firma and the rear wheel spindle remains constant.
    Please be more careful with your analysis, obviously the only way this can happen is if you put more air in the rear tyre.
    500 psi should do it.
    Alternativly remove the silencer, this generally increases power by upwards of 37.3 %.
  2. Along with all the other mods, I now reckon I might need to raise the gearing a little. I currently have a 60 tooth rear sprocket. I was thinking 56 might be better?
    As the sprocket is aluminium I was thinking if I got the dremmel in and ground one tooth off every 90 degrees that will do the trick ?
    The down side is that if i need to go even higher i will have to grind off 4 more teeth (to keep everything balanced like)which might be too much , so would it be be better to start by grinding off one tooth every 120 degrees and then if i need too I could remove another 3 ?
    Easy way to raise the gearing is to get longer shocks.
  3. there was a steep slope dropping down into the river at bayford woods. It was a bit muddy so I just rolled in (off the brakes). Came in a bit fast, front wheel locks in the sand I get thrown over the bars head first into the cold water.
    Not very nice riding a cold trial in the middle of december after going for a swim :guinness:
    Reminds me of Michael Tye of Oban, flipped the bike in a steep burn, ended up on his back in the burn with the bike on top, water flowing in through the waist of his jacket and spouting out the neck.
  4. Sorry, but beg to differ. I have had Iris chains on all the GG Pro,s including latest Raga, never a problem with the chain lasting.
    Use whatever chain you want. Personally if I read of recurring problems I try to avoid the potential problem.
  5. I gather you're a purist, thats fine. I'm just wondering if there are alternatives to spending close to $400 on a pair of boots. I have spent allot of $$$'s on gear over the years and I don't mind doing so if its the 'only' way to go or even if its the optimum way to go. I don't mind at all trying to save a few bucks either. I wouldn't know if I didn't ask.
    Thanks,
    Bark
    A large proportion of injuries are to the lower leg, hence my comments. I would never ride with these, I never ride without my plastic shin / knee protectors either.
  6. Quiter simple really. You are only asked to pick your number twice but the number groups change each time so the system can easily work out which number you've picked. If you record all the numbers in your first choice colour group you will see none of them appear along side your number in the second choice.
    You had to spoil it didn't you, I thought it was majic.
  7. THE MIRACLE OF TOILET PAPER
    Fresh from my shower, I stood in front of the mirror complaining to my
    husband that my breasts are too small.
    Instead of romantically telling me this is not true, he
    uncharacteristically comes up with a suggestion: 'If you want your
    Breasts to grow, then take a piece of toilet paper and rub it between
    them for a few seconds every day'
    Willing to try anything, I got a piece of toilet paper and stood in
    front of the mirror, rubbing it between my breasts.
    How long will this take?' I asked.
    They will grow larger over a period of years,' my husband replies.
    I stopped. 'Do you really think rubbing a piece of toilet paper between
    my breasts every day will make my breasts larger over the years?'
    Without missing a beat he said 'Worked for your bum, didn't it?'
    He's still alive, and with a great deal of therapy, he may even walk
    again although he will probably continue to take his meals through a
    straw.
    Stupid, stupid man
