It's good for Raga ,Cabs and co. 'cos the only reason I went to the show was to be hypnotised into making me a better trials rider than Mr. Bou...so there..I've put the World title attempt on hold for the mo'.
Should that not be "put the world title attempt on hold for the ma"
This one has a clutch, tho generally they just use it for starting. Interestingly the driver is using the right foot for braking, usually they use the left.
Thanks i was pretty sure i heard about those B40RT but never seen one. Tried google but without succes i,ll try again what comes up using rotech in my search
Seat pad was cut out of some thick foam with a modified jig-saw (ground the teeth off a blade - works a treat). I will see what I can do. OKO carb is on the phase 2 list, too.
Roger
You can buy blades from screwfix with no teeth to cut similar materials. (its a sharp wavy blade)
Was at a cart race where they were using water cooled twin cylinder rotax motors, 250 I think with 6 gears. Rotax also make engines used in microlites, both 2 stroke & 4 stroke.
If any of you have seen Derren Brown live you will realise that this is one of his type of observation tests.
Another one is the ping pong doubles team that turn into gorillas.
What it's used for is not to highlight your powers of observation or your ability to spot misdirection, but your ability to focus on the task.
I'll not bore you with the psychology behind it but if you laughed out loud when the gorillas/bears appear(as I did) then you are 'generally':-
Easily bored.
Have the attention span of a small child.
Have an inability to concentrate or focus.
Lack determination/ willpower.
Far too willing to accept a compromise.
Will under achieve in most aspects of you life (job,relationships etc..).....
...And so the character assassination went on ..and how the audience laughed at my expense. .. when I was singled out.
On the plus side he said he couldn't ''work'' with me as it would take too long to hypnotise me and it was 'unlikely' that anyone would ever sneak up on me .
I think it is perfectly reasonable for a UK petrol station to see your risk assessment and method statement before you fill up your 5 litre can.
Here in Dubai, the bloke at the pump fills up your car, petrol can etc with you sat in the car, engine running on your mobile phone, smoking a fag. Oh and its dirt cheap.
thanks Jon & Tim looks like I'm not engaging the kick start properly before giving it a good wellie too. mines working now but still not to sure about it but that might be me being a bit paranoid. Jon if the needs be would i be best replacing the whole internals gear idler spring and shaft or is that a bit over the top cheers Paul.
Never had any problems with plastic cans. Petol stations thats different, you have to hold it above your head so thay can see it before they will turn the pump on. Never heard of anybody having an actual problem with any sort of can. Wish "they" would turn their attention to things that actually matter.
Montesa 247 Cota Kick Start
in Twinshock
Are you very big, or is the bike really small. (father ted sort of question)
