Remember years ago when they were making Braveheart?
Everyone was saying, "Oh, its ridiculous; Mel Gibson playing a Scottish guy?
That's not going to be very convincing!"
But take a look at him now: an alcoholic Racist!
A man and his wife go to their honeymoon hotel for their 25th anniversary. As the couple reflected on that magical evening 25 years ago, the wife asked the husband, "When you first saw my naked body in front of you, what was going through your mind?"
The husband replied, "All I wanted to do was to f*ck your brains out, and suck your t*ts dry."
Then, as the wife undressed, she asked, "What are you thinking now?"
He replied, "It looks as if I did a pretty good job."
Interviewer : Would you ever consider going down on one knee again?
2 complaints after the show was it? Then the press get hold of it and every bugger gets on their high horse - get over it, it's not news, they were paid by the Conservative party to create a smoke screen
Two complaints ? that was both the people that listen. Thinking of claiming I sha99ed her as well, maybe the BBC will suspend me on
Doesnt clunk on a B40, and theyre all basically the same. You could turn the cam plate upside down and see if it works better that way. ie 1 up and rest down.
Im a welder myself and to be perfectly honest with you you dont need to disconnect anything.Just make sure that your earth clamp is directly beside where you are welding so it cant travel through the rest of the bike.
Cheers Dougie
You didnt watch long way down then - half the electics on the BMW's didnt work after electric welding.
It is a bronze bush, it is a bit tricky to get into the motor but it can be done - prise open the motor housing carefully then separate the 2 halves, usually no lube is required because of the bronze bush. If it is making a noise then I reckon the shaft surface has deteriorated and lubing is a short term answer. I agree with Jan, WD-40 is not such a good lubricating oil and it does tend to dry things up eventually.
Bye, PeterB.
Hi PeterB
I used the soak it in oil on the fan motor of a fan assisted oven many years ago, its still working. (but will now stop immediatly, I have no doubt)
Can be one of those jobs that takes 10 minutes or hours and hours. Pushing the fluid back from the bleed nipple to the reservoir could push the seals in the master cylinder back on themselves. I hung the bike from the garage roof by the front wheel getting the reservoir as high as possible and get the brake hoses in as straight a line as possible. Air bubbles are trapped where the hose enters/exits the swing arm. Bleed the brake with the rear brake pedal, gently tap the brake hose in between, then finish off by pushing in the caliper piston with the bleed nipple cracked open. It can take ages, good luck
I thought I was the only one who resorted to weird things like hanging a bike from the roof, still, if it sorts the problem !!!
I thought I wa the only one who resorted to weird things like hanging a bike from the roof, still, if it sorts the problem !!!
Brand & Ross
in Anything goes
Considering how tallanted and popular Brand and Ross are supposed to be, they have virtually nobody defending them !
I for one wouldn't miss their witterings.
