b40rt
    6,076
Posts posted by b40rt
  1. It's a 2 stroke, they smoke. Burning gear oil smells quite differently to 2t oil.
    Crank seal on dry side would normally make it run lean, i.e. not a black plug.
    Woodruff key tends to be instant, not gradually getting worse, and the result of a stuck open throttle "incident"
    If it was running well before, the jetting etc should be right.
    • Like 1
  2. 1 hour ago, jimmyl said:
    It’s an easy measurement so don’t think that’s the reason - think more the marketing is now done by “branding experts “ as they say on the  apprentice rather than engineers so graphics are more important than mm ( inches for the pre 65 brigade) and degrees ??
    ? Think you'll find there has been more development in pre65 's in the last 20 years, than in " modern " bikes
    • Like 4
  3. The hole is very small (which makes it block easily) Soak it in carb cleaner / brake cleaner, blow out both ways with an air line. Guitar strings will clean it but this is NOT recommended. When you last put it away it was running ok ? It so, did you drain the carb ? No ? The fuel will evaporate and leave deposits / varnish, this is probably the problem.
  4. On 11/19/2018 at 9:17 PM, Russ Bedford said:
    Up to yet I've checked the fuel,installed a new inline fuel filter,cleaned and oiled the air filter,had the carb ultra sound cleaned,all the jets cleaned ...
    8 hours ago, Russ Bedford said:
    Evening chaps..the latest in my shenanigans..is this my pilot jet,and shouldn't there be a hole through it?IMAG0960.thumb.jpg.98341e1f65dd4aae367173d7c86d019e.jpg
    This should have been your first post ...
  5. 12 hours ago, kamikazecowboy said:
    OK, from looking at the abuse the tlr200 reflex owners get I'm ready to sling **** back ; Got one for free ( best part so don't go off whining buy something else), motors seized up will take apart and find out why some other time BUT in the interim Would an XR/XL/ATC 200/250 motor of earlier 80's vintage be a bolt up swap?  Yes as a fab shop owner I know I can make anything fit so please don't go there, I'm just looking to get a beater running for when my trail-pig ( klr650) is getting married to a sidecar this spring Ive still got something to run around on and maybe teach the wife how to ride. Not looking to build a trials bike  ( yes I can hear the whining already buy something else, I didn't buy this so get over it). So the cost is already no relevant except for a used motor
    Is this a question, or just a rant ?
    • Thanks 1
  6. 12 hours ago, al_orange said:
    That of all the brands, it seems like TRS riders are the most likely to go full "power ranger" with the TRS clothing? Do they come cheap with the bike or does the bike attract a certain type (like with BMWs). I'm a tart and I'd like a shiny new TRS RR but I don't think I could bring myself to wear the kit too... But then I'm a fat old man..
    Thoughts? ?
    Repsol Honda riders beat them hands (and usually feet) down.
    • Like 1
  7. 3 hours ago, pindie said:
    I’ve just put a new BPR5ES plug in, the previous one was original! New one is now dry, sooty and black so definitely rich. I also have a new BPR4ES to try.
    A hotter plug will only disguise the problem, not cure it.
  8. On 8/5/2017 at 2:33 PM, scot taco said:
    What is the correct procedure for setting the points gap?
    I had the primary stator coil give up the ghost this spring.I then put the lighting coil in its place along with a new set of points and condenser.Checked for spark,which was good and back in the corner she went until last weekend.
    It was very reluctant to start and when it briefly did it sounded really out of time so I shut it down and took the Sherpa T.
    Maybe there are other problems in my using the lighting coil,but I would like to make sure that I have the points set correctly before anything else.
    I think the way that I did it was to turn the flywheel until the points looked to be fully open and then set the gap? I want to give it one more try before I order up a new electronic ignition.
    Does the lighting coil and the primary coil have the same part number ? If not, its unlikely to work properly over the full rev range.
  9. 2 hours ago, nhuskys said:
    I also rode a TRS and liked the S3 Curve footpegs, so put them on my Scorpa.  I'm a clubman rider, but I benefit being short, that they help me get more forward on the bike and improve my overall riding position.
    @lineaway. There you go, someone moving footrests forward to suit their size, just like Danilo Galeazzi !
    • Like 1
  10. On 12/6/2018 at 1:07 PM, lineaway said:
     After riding my sons TRS, I bought the curve footpegs for my Beta. Huge difference.
    And yet moving footrests on a twin shock is just lazy !!!! Which is it ?????
