b40rt
    6,076
Posts posted by b40rt
  1. 42 minutes ago, ironbelly said:
    @b40rt seems you wasn't happy with your first reply that didn't get a response? So you want another go? I jumped the gun on the thread and private messaged those saying so! The fire has gone out and left the building fella.
    @ironbelly  It is an open forum !!
     I've just never found the argument "if you disagree with me you must be jealous," a very convincing one.
    • Like 1
  2. I have used leather boots from many manufacturers, they all get soft and lose some protection, when saturated.
    Sidi, being made of Lorica, don't seem to suffer from this. I initially found them a bit clumsy, but soon got used to them. Definitely the best protection I've experienced. (Incidentally, they are small, go up one size)
    • Like 2
  3. 1 hour ago, nigel dabster said:
    the rules are there because Andy wishes them to be afaik, and he has what seems to me sensible reasons for them.
    If you chose to disagree take it up with him.
    I was only pointing out the obvious at least I thought it was.......
    afaik - Andy's rule book - no text speak !!!!!!
  4. Notable trials coming up in 2018 - Pre65 Scottish and SSDT. http://www.ssdt.org
    Highland 2 Day  http://www.idmcc.co.uk/highland-classic-trial/
    To compete in either of these, your biggest issue is going to be insurance. Both events would require re-patriation of some sort, usually from your governing body, IF that can be arranged ! Check this out first as your medical history will have a significant impact.
    • Like 1
  5. On 16/12/2017 at 10:06 PM, turbofurball said:
    without any coordinated system for checking VINs at all trials venues that probably won't change.
    Doesn't sound like you have much faith in the police ?
    What database will the VIN's be checked against ?
  6. 3 hours ago, oni nou said:
    Plastic disc guards usually have a metal insert that stops the plastic being crushed and distorted and enables the head of the bolt that screws into the calliper to clamp tightly to the metal surface of the metal anti- crush insert.
    Echo ....
  7. 40 minutes ago, trapezeartist said:
    And one of the two bolts holding the front brake caliper also holds the plastic disc shield in place. That's a biggish bolt (M10?) that's reacting brake torque so you really don't want that one working loose.
    Metal inserting plastic shield ?
  8. 1 hour ago, dadof2 said:
    The original MAR was primarily developed for riding slippery stream beds as that is what many of the sections were then. With the lower grip of tyres at that time too little damping would cause the back end to kick sideways and slide off boulders. The stiff damping was right for the time and the tyres but certainly will feel much less bouncy than modern suspension.
    Think your analysis is about 99% out !! (@pmk, incorrect)
