Not done this to bultaco's, but see no reason it wouldn't work. On Rotax first box, cut window, leaving enough meat to fit plate over whole area, fit 4 small rivnuts, repack, seal edges with high temperature silicon. Allow silicon to cure before use.
Erm... working properly and changing pull effort are two entirely different things. And something tells me the clutch on a modern TRS is better in just about every way than an old Bultaco, but maybe I'm wrong...
It's not working properly if you can't pull it, or have I missed the point ?
If you left fuel in the carb, and your petrol is as carp as ours, I would clean it again. A small amount down the plug hole, as suggested above should fire it up if it's a petrol issue, 10mm approx. Is the plug wet after trying to start it ?
Hi fourex, that seems a good solution, I'll contact them
b40rt, thanks for the link, I was hoping for a straight on picture so I could trace it but that will be a good reference if I do wind up making them.
You can't really put stickers on plastic tanks as they breath fumes ! I had an swm italics badge engraved onto aluminium plate. Looks good IMO, but obviously not original.
Just off the weeji board to my mummy, she agrees with you.
But she also said to check your blood pressure, and when a cruel big boy suggests its not that smart to ride by yourself with a joke helmet and gopro (which are banned from competition here after Shumaker's accident) you over reacted just a tad.
I think it was the 349 Monts that had a quick release gearbox sprocket mechanism to enable gearing changes to be made quickly by the rider, In this case the main aim to give the motor an easier time on the roads.
The 349 was good for 70mph or more, how much faster would you want to go ?
MH349 Noisy WES Exhaust- Is This Normal?!
in Twinshock
Posted · Edited by b40rt
