Took the side cover off and sat looking at the clutch for an hour working out what pushes what etc.
Had a chat with the local Bultaco/Greeves/BSA engine builder and racer he suggested just winding the nuts off a couple of turns and see what happens. Yeah - why not!.
There are six plates on my clutch.
The actuating rod, lever, cable were all good and moved nicely.
Took off the clutch arm return spring - the clutch was 'closing' well enough without help from a strong spring as well.
Wound the nuts off a couple of turns - from about 6-7 mm threads showing, to about 3-4mm showing.
Spun it over with the kickstarter looking for runout (very difficult to see any - if any)
Started it with no cover and rode a few yards to see if I could make the clutch slip. Seemed fine.
Wiped off the thrown oil! and back together, new ATF and away we went.
Much better, nicer action - not light as the 325 but very much improved. I wasn't thinking how heavy the clutch was every time I used it or came to a stop.
Had a great time ripping across the stubble. did about 8 miles. No slipping. Great.
Ahem. One thing did surprise me. I put three litres in and drained two out.
If you have extended the operating arm your cable may not be long enough to allow for this. Take all of the adjustment out both at the lever and at the bottom end of the cable next to the cylinder. If still no good you need to extend the cable inner. (New cable)
Or carefully shorten the outer, if cable is long enough.
You quote a few slippery (solvent) businesses, I quoted an entire nation. Therein lies the difference...but I think you knew that already? The socialist utopia is crumbling,comrade.
Everyone talks about the 'the trial that cannot be named up North' with rose coloured glasses, yes there is scrutineering but it is a joke, lots of bikes look nothing like the pre 65 originals and no one has the balls to object.
So the pre 65 Scottish scrutineers have to "police" the entire pre 65 movement ?
80% of the entry are only seen up here once a year, over to you and your big balls
Ebc Brake Shoes For An Italjet.
in Italjet
