merrydeth
11 -
http://www.trialendurodirect.com
I think he might of meant its never been won on a Gas Gas Pro ? Steve Colley was on the Txt......
Ben, you should keep to just reading the posts because you obviously don't no what your talking about little boy !!!!!!!!!!!!! The inserts will NOT fit any of the standard cylinder heads, ONLY the "Stars" one.... They do make quite a big difference though once fitted, the High compression is the best option for the 125 as the very high is kept for when riding in places like Andora to get more power out of the bike, if you use the v.high straight away there's no way to get more power out of the bike.....
Anybody thinking of going to the Hipwell trial this year??? same venue & start is in Peak Forest. Hopefully it will be another mega days trialing on land that it only used once a year. 2 laps of about 20 sections with only about 5 miles of road work, only need to re-fuel after first lap back at the start. It will be a Cheshire centre champ round but you can enter on the day for no champ points. Should be a real good day as long as the sun shines like it did last year..... merrydeth
I don't think that is quite right Ben, spoke to GGUK and they said that your dad had connected them both up wrong! Now he's spoken to them and your now connected up right the carb is perfect.....
Think he sorted his problem, apparently he was putting the fuel pipe from the petrol tap straight to the bottom of the float bowl, not where it should be and that was filling the float bowl up and then out of the overflow.... Sounds like rider error ah, not the carbs fault......
Hi The correct mix is 65:1, which is 15ml of oil to 1 litre of fuel. (75ml to 5 Litres of petrol)
. Went to lend a hand to the Hipwell brothers yesterday, to cut the sections in for this sundays trial. Some mega sections as the great english weather last month has open all the sections up a treat.... If you want a mega 2 laps of 22ish sections then get yourself to Peak Forest this weekend! Enter on the day and only
Went to watch the "Reeth 3 day" trial at the weekend & spoke to "Factory Kev" from GGUK about his 225, he has got 2 flywheel weights fitted with a keihin carb & Raga reed block, also with a short titty pipe... It sounded "Awesome" when he had it flying up the sections!.... It must go alright as he won the clubman route on it! Oh, he also had titanium footrests as well...lol
. Hi, went to the Tom Wycherley cup at Hawkstone Park last saturday, just wondered if anyone knows where the results are, can't seem to find them ? Mega trial though........... .
What do you mean wayne, me no understand ?
