my transmission parts arrived on Thursday, that night I found out I have an opportunity to ride with the Neiderer brothers on Saturday (today) So Friday evening I reassembled the engine and rest of the bike. Took me a little while (hours, too many to admit to and a couple )
but she is together.
So before heading out to ride today with friends and the Neiderer boys, I fired up the Old BAGG to put around the yard to verify all going well.
All did not go well, she ran like crap. I blamed it on the copious amounts of 2 stroke oil I used on the cylinder and piston for the reassembly. so off to the trials property, met the boys. Very nice guys, easy to chat with. No big egos getting in the way. and very very good riders.
My bike continues to run like crap, revs way high on choke and bogs out when given throttle and take forever to idle down. So with those symptoms if you guessed "sucking in extra air" you win a prize! go to your nearest fridge and retrieve your prize. (I am too cheap to supply one)
My buddy Biff, the great thinker, suggested spraying carb cleaner at the base gasket. and guess what that caused the bike to stall out. DING DING found the problem, base gasket sucking in air. but why??????
It turns out in my haste last night to reassemble, and the use of assembly fluid , I had left a 1 inch piece of the old base gasket on the cylinder when I put it back together. Break out the tool box right there in the parking area, time to fix the Old BAGG so I can give her a proper thrashing. And yes everyone thought "this is kinda sketchy, but if it works it will be cool" I took off the carb, motor mount to the cylinder, header pipe, remove water pump from clutch cover, basically whatever I needed disconnected to be able to lift the cylinder up about a half inch. Lift the cylinder and use a this flat head screwdriver and needle nose pliers to gently remove the offending piece of base gasket. Reassemble the bike and viola it runs like a top again.
Off to play and watch others. Alex and Andreas are very talented, riding up near vertical hills out of creek with only a bike length run at it. Rear wheel hopping two logs and then to an elevated log. just so much going on, Both are very smooth. I was highly impressed. I was also impressed with buddy Biff, he was trying most of the stuff they were riding, total mental. Both of them would chat with us, discuss various techniques. Great couple of guys.
about 15 mins before everyone was done for the day my bike decides to act like she is starving for fuel. So I am now off to the garage to clean my carb.
Thanks crazybond for the pictures. I called Stuart at Jacks Cycles. He says at the moment the rear rubbers aren't available from GG, so I'll be fabbing my own it seems.
I needed to replace the rear rubber on mine and of course it was not available from anywhere.
so I replaced the front rubber with a new one and cut the front section of the old one off to use as a replacement rear rubber. Don't know if you currently have a front rubber piece that you could do that with.
Find a cheap Mini truck , make it reliable , and go ride !!!
I've got a 2012 Nissan NV 1500 Cargo van , That I bought expressly for hauling bikes and camping , but I don't get enough time to go compete , so I use my van for a Daily driver ....But I might put a trailer hitch on my hot rod Miata , just for fun ! But I do LOVE my van !
Glenn
Talk to Biffsgasgas about how to get that hitch on a Miata. he successfully pulled a 3 place open trailer with his for many years. Was the coolest car to roll up in the pits.
And moved some logs etc around the trials property as well.
Also if you need a roof rack on the Miata he is the man that know how to make that happen.
try a different technique. I went from a Sherco to a GasGas and the starting technique is definitely different.
For the Old BAGG (Old Bad Ass GasGass) I have her either on a bike stand or leaned against a tree or other suitable holding device (truck, friend etc.)
Stand on the pegs (both feet)
place foot on kicker and gently push down until feeling resistance. (gears engaged)
swift, smooth kick downward and vroom vroom .
After replacing piston and rings she starts up 1st or 2nd kick now. cold or warm.
before that when cold took many kicks and when warm would require the choke to be on.
good luck, hope you get it sorted and have more energy to ride instead of kicking the bike over.
2008 250 Gasgas Pro Swingarm Bushing
in Gas Gas
Did you tighten the swing arm axle bolt with the motor pinch bolts loose?
