zippy
    3,372
Posts posted by zippy
  1. If it has a history of running good until one day just is not running well, I would suspect a blocked jet.
    Take the carb apart, clean it.  throw it back together and see if it's fixed.
    32 minutes ago, tshock250 said:
    Is that an enduro bike?
    I believe so, but still a GasGas and basic running principles are the same.
    (Maybe we can convince @mastermatt to buy a GasGas trials bike too)
  2. 10 hours ago, cmccoll said:
    @zippy
    Thanks for the reply, I just need to speak to some breakers and see what comes up. What year was the wheel you put on your 03?
    I believe it was a 2015.  Just be sure to use your spacers that are original to your bike on the new wheel.
  3. I fitted a new style wheel (2-piece spoke) to my 2003 GasGas. It was used (much cheaper than new) and came off another GasGas.
    Fit right on, just had to use the spacers that were original to my 2003.  No muss, no fuss.
  4. Can you get a clamp of some sort in there.  Maybe a small version of this.  one side on the bolt threaded area the other side on the frame next to the bolt hole.
    Push the bolt back toward the shock, eventually having enough bolt shank showing to grab with pliers.  this is of course assuming  you can get the nut off or cut off the nut.
    IRWIN VISE-GRIP Welding Pliers, Fast Release, C-Clamp Locking, 6 ...
  5. 11 hours ago, v1nn1e said:
    Found a local car park where I can practice during this virus lock-down.
    There's a flood drain opening built in to the side of the bank just off the tarmac, the wall of which is about ~2' 6" - ish or so. Not done drop-offs from that height so here we go...
    Did 4 or 5 and finally landed both wheels together. Not sure why that put more force through the pegs but because I was standing too far back it jerked the front of my foot sharply upwards and I've effectively sprained my right ankle, not too bad hopefully :( . Left was OK thankfully.
    I should have learnt from watching Guy Martin's Great Escape, where he did the same, landing after a jump. Have now realised, the hard way, that I need to position my foot further forward so the force goes straight up my leg.
    Just a warning for anyone else at the same stage. :)
    If this happened at any point in history other than now, the responses would be totally different.
    So let me give a different type of feedback:
    Yes, proper landing technique is key when doing drop offs, thank you for pointing out one of the possible negatives of doing a drop off incorrectly.  heal up quick, but take the time necessary to do so.
    Land with rear wheel first seems to be the best way, and as you said have the feet more forward on the pegs so that the ankle does not "dip down" when landing
  6. @mbeers6 sorry for taking so long to respond, bike maintenance has taken a back seat lately.
    I tore down the dog bones today.  As you can see in the the VXB photo of the bearing there is no seal.
    Here is a photo of the same bearing installed in my dog bones.  (Still a bit dirty, but hopefully can see it clear enough)
    note: it is a caged bearing and there is a rubber seal, I "persuaded" the original GasGas seals to be in place. It is a very tight fit and the seal does stick out probably a half mm from the dog bones.  but after install in the bike, they don't stick out anymore.  SQUISH!!  ?
  7. A friend in Germany mentioned the next 2 trials events have been cancelled.  Events with more than 75 people are currently banned in their area.
    Here in the states I have not heard of any events being cancelled, but it may be a regional thing.  MOTA doesn't have any events scheduled until May 17th.
  8. 45 minutes ago, motovita said:
     I share your opinion of mag switches, but they are required for snowmobile racing. I assume they are mandated on Trials bikes as a safety issue for spectators, I see very little chance that they would ever prevent or minimize injury for a rider, and as you suggest they can cause an injurious dead engine crash. It seems many people consider them protection for the engine, personally I find paying for engine repairs preferable to hospital bills.
    I have medical insurance............. motorcycle doesn't.............
    but that's just me being a smartass
  9. 7 hours ago, mbeers6 said:
    I use the same bearings but don't reuse the old "seals".  Don't the bearings have seals built in? How would you fit in the old outer seals?
    Thanks just trying to learn.
    Actually been a little while since I changed the bearings.  If memory serves correctly, (this may be the issue and as I type this I may have remembered differently) the new bearings are just a touch wider than the originals, I believe I put in O-rings to take up the gap or I was "persuasive" with the old seals.  I actually need to grease the dog bones bearings soon.  I should take a pic and post it.
  10. 5 hours ago, utahpete said:
    10-time US trials champion Pat Smage giving his all in Europe. Good reminder of just how good the boys from the "continent" are. Nice to hear how humble he is, but wow, what a brave young man he is to even show up! Great job Pat.
    https://youtu.be/fDOtelRNhUc
    I really enjoyed his commentary through the sections, was interesting to hear what he was thinking etc..
    • Like 2
    • Thanks 2
  11. my GasGas starting procedure - from cold choke on - from hot no choke
    Lean bike against appropriate item (tree, truck, garage, etc) OR have bike supported by skidplate (on stand, on a log, on the neighbors annoying bratty kid......)
    Stand on the footpegs
    Bring kickstarter down gently until you feel resistance
    From that location kick through with a forceful fluid motion - gotta get it to spin up quickly, but don't "stab" at it
    NO throttle
    Mine starts 1 or 2 kicks 99.9% of the time
    • Thanks 1
  12.
    On 12/19/2019 at 11:24 PM, featsupppp said:
    The video makes it sound like KTM will introduce a GasGas trials powered by KTM by model year 2021.   I think that's pretty exciting.  I want one now!
    In the video he says the "off road" bikes will be based on the KTM platform.  I understood this to be Enduro and Motocross.  Whenever Trials is mentioned it is specifically called out as Trials.
    • Like 2
