zippy
    3,377
Posts posted by zippy
  1. Hold the bars "loosely" don't have them in a "death grip".
    Sounds like you are covering the clutch so that is good. Keep one finger on it.
    and yep practice, practice, practice. Like 0007 says, practice throttle control specifically.
    also try slipping the clutch, kinda like working the throttle against the clutch. Hold throttle with some engine RPMs (low) and use the clutch to keep yourself staying in one spot. It is ok to first try this with your foot down to get an idea of what everything is doing. This may help you control the throttle and get used to the relationship between the throttle and clutch. (also useful in tight turns)
  2. Well, this was not today but last Saturday (day 1 of 2 day event). I lost all rear brake, push pedal down and it went past the skidplate, no pressure.
    So right in the pit (paddock) area in the middle of the event I rebuilt the rear brake master cylinder. Remove the two bolts that hold the master in place on the frame and wiggle it around so that the master is between the swing arm and the muffler with the bottom pointing out. Pop out snap ring, pull out plunger, spring and remark about all the crap that was in there on the seals. Then shove new plunger and spring in and get the snap ring in. wiggle it around and remount it and VOILA I am off and running.
    This whole thing got me thinking about maintenance and repair. When these things are done at home in the garage/shop most of us are very meticulous about making sure everything is clean! Make sure there are no bits of dirt, metal etc. within 40 feet of whatever we are repairing. But in the middle of an event, when we need to repair and get riding this is basically what is running through my head "Just Shove That Part in there, Dirt don't matter, GO GO GO!!!!" :o:rotfl:
  3. Fingers crossed that it does fix it without needing to split the cases again. Hope it hasnt cost too much so far. Its a great feeling when you solve the puzzle and you should have a good bike when its done.
    I sometimes think every one should be made to strip and rebuild a motor just to see what happens when you stomp on that gear lever with a size 10 boot or stab at the kickstart with out taking up the slack in the gear first. It makes me cringe watching some people starting there bikes, a guy told me on Sunday that he had snapped three kickstart shafts and thought it was a design fault, Then I saw him start it. :wall:
    Sorry slightly off topic rant there.
    TLTEL
    Solving the puzzle is a great feeling.
    I agree about riders understanding how the internals of the motor works. They all may not have to be able to split the cases and rebuild it, but at least should understand how it works.
    I tried using the shift lever on that sherco I had as a foot peg once, I got all out of shape on a drop off and my foot came down on the shift lever instead of the peg.................SNAP there went the shift shaft.
    And they do start much easier taking up the slack first.
  4. Majority of the Beta owners I see with the lefty kickers have gotten used to it and have no trouble kicking them over, so it can be done. :D
    Beta 4t's have it on the correct side though...................maybe Beta is giving in to peer pressure to be like everyone else. :o
    All wives are unreasonable, and it is always the bikes fault!
    HAHAHA
    Welcome back to trials.......................... now get out and ride!!
  5. Thanks for the welcome chaps. I started on a 1973 montesa cota 247 when I was 14 in 1995, quickly got shot of that onto a very modern Beta TR34. Then a 1994 Techno and 2 x 1996 Technos. From the small go I've had on the late 2000 bikes they seem epic. Can't wait to fire it up a few hills!
    Fantic Section - kickstart was on backwards wasn't it?!?! :lol:
    Yep, at least it was on the correct side unlike Beta's :D
    My foot slipped off that silly Forward kick Fantic more times than I want to count. I really knew it when the kicker embeded itself in my calf muscle. OUCH!! bruised of course, finished riding of course, whined and cried to wifey for some sympathy at home of course...................................... She shook her head and called me "stupid man" and walked away.........of course :D
  6. Rear brake is as important as the Clutch
    Zippy, The rear brake is as important as the clutch, Obviously modern bikes make it easy, everytime the wheel lands the brake is on, just letting the rear brake off when flicking the clutch!! Now get on and practise mate :icon_salut:
    -Jason Finn
    Practice?????? What is this practice you speak of?
    :rotfl:
    I wasn't exactly sure about the rear brake.... figured I would get corrected if I was a bit off on that.
  7. Over the 7 or 8 years I owned that Sherco 2.9 I got REAL familiar with the insides of the motor.........................................Sometimes it was something I did that caused me to need to split the cases and fix it :wall: other times was just normal wear and tear.
  8. I also wonder if the kickstart is partially engaging going on the video.
    The 2000 2.9 I used to own had that problem. There is a small replaceable metal piece that separates the kickstart gears when not in use. this piece wore too thin and did not separate the gears completely. Piece 5.15. it can be accessed by taking clutch cover off............too bad coolent will need to be emptied to do it.
    3045.jpg?1358377294
  9. If you plan to remove the swing arm don't forget to loosen the pinch bolts where the swing arm axle passes through the motor.
    All in all a pretty straight forward job.
    I just did mine (2003) recently. Also some riders "flip around" the "triangle" piece under there so that the bolt that threads into it will rotate to tighten on the down stroke of the suspension. Some have had this bolt loosen periodically and it hits frame, etc. when it works its way out. The "triangle" is "reversable" so to speak.
    (man that last paragraph is about as clear as mud :stupid: )
  10. Welcome to the sport..... I love my 2003 GasGas 300 pro
    These modern bikes are wonderful, in my youngster days I was on TYs (80 and a 175) got out of trials in my teens. jump ahead many years got back into it on an 86 TLR 200 Reflex, couple years went to a 95 Fantic Section (HUGE difference) later got into bikes from the 2000's and another HUGE jump ahead.
  11. Good luck with that, I cant help thinking their standard not be good enough, here's hoping Im wrong. But before anyone gets the wrong idea its the level of competition we have here in europe and the european championships that give the eurosfrom a very young age head start.
    Sure complain that we need more riders in the WTC, but then try to discourage anyone that is not from Europe from attempting the series.
    How about waiting to critique their performance after they have had a chance to perform.
    Bou won't be #1 forever, Raga, Fuji, Caby, Fejardo won't be able to ride forever.....................We need some of these "younger" riders to give it a go, From whatever countries they come from.
    • Like 2
  12. Going just off the title
    I am sorry that the bike is lonely and in need of a date. I would have been interested in my younger days, but alas i am a happily married man, (at least that is what she tells me) :chairfall:
    I did do some Google searching and I was unable to find anything to help determine the year. sorry about that
  13. I was at an event and there was a nice young lad about 13 yrs old riding a 125cc in the same class as me. I watched him basically walk that 125cc up a rather steep tall hill. I thought "well, I should be able to get up there, I am 3 times older and I have a 270cc!" As it turns out I could make it 7/8 of the way up the hill......and all the way back down. :rotfl:
    lesson learned, That kid is an excellent rider, and a pleasure to talk with also. so :thumbup: to the young man.
    Good luck to him and may he go far in the sport.
    (it takes a special type of person to be able to accept being beaten by a youngster and be able to congratulate them and actually mean it)
    • Like 2
  14. For North America, road legal trial bikes with tank and seats(kits) will X 4 their sales. I know this for a fact. That will put a lot of riders on trials bikes as it did in the 70's. With enduro riders now Xtraining to trials the stage is set. cheers.
    There only 2,500,000 views on this video. :wall: Manufacturers, take advantage of this!!! This is a trials revolution now entering the massive enduro world.
    The following is my opinion as it relates to Trials in USA
    This is actually part of the problem not the solution for Trials. Riders of other motorsports (IE enduro, motox, woods, GNCC etc.) do recognize the skills that trials provides but they only see it as a way of adding skill to their current chosen sport. They do not see it as another serious option of competition. So these other riders will considering buying used bikes and just put around the yard or go "play" at the local riding area, and no interest in entering events. So maybe there are some indirect new bike sales, (guy sells old bike and buys new or newer bike and so on) but the sport of trials will not grow because we do not get new competitors from this type of "cross training".
    Just my opinion,
    • Like 2
