zippy
    3,372
Posts posted by zippy
  1. They are fair questions, is it a open forum and should the public know of a genuine concern?
    Will users want to know?
    Will it be allowed?
    Yes those are Fair questions about whether it will be allowed and if the other users would like to know.
    What is unfair is the immediate jump of comparing the owner of the site to a dictator.
    (As far as I know Andy has not had much to do with potatoes :P )
    • Like 1
  2. I walked past my new to me 2003 300 (as I understand first year for the 300) in the garage and gazed lovingly at her and imagined all the things I wanted to do while riding her. And like Mr. Neutron 5 minutes later I was tired and breathing heavily, went back in the house.
    I have ridden the bike twice as a put put around and in a 2 day event that was very rainy and I loved the way it rode. Of course going from a 2000 Sherco 2.9 to a 2003 Gas Gas 300 pro I will have some adjustment time, but I love the motor. I may gear down my sprockets a tooth or two when I need new chain and sprockets. Things seem to happen just a hair bit too fast. I need to figure out why the rear tire is loosing air way too fast. (I suspect I need a new rim strip) Change some fluids, clean air filter and I am good to go. I am considering putting on short levers, I had some on the Sherco I really liked them on that.
    • Like 2
  3. Thanks folks, it does seem to be a "win" for the chest mount, other people have said the same. This was the first time I've used it, and as is typical with a Gopro, you can't really tell until after the fact if you have it pointing the wrong way! I'll try to tilt it up a bit further next time, as you do see too much of my knees in this clip.
    Cheers
    Mark
    But those are some perty knees! :wub:
  4. Good job editing out the boring bits of standing around between sections and waiting in line. But I did like that you included some shots of other riders also, gave another type of perspective for the camera locations.
    The helmet mount seems to have a "downward" view of the terrain and gives a slight distortion (flattening) to the obstacles and angle of the hills. But it also gives a wider of the area around the bike.
    Chest mount has a more "straight on" view of the terrain and seems to eliminate much of the distortion (flattening) of the obstacles and angle of the hills. But it seemed to include a large amount of the tank/bars of the bike and not the area around the bike.
    I think the chest mount has the better angle of view, now if we can get a slightly different angle to include more of the terrain around/in front of the bike it would be the best of both.
    Just my opinion.
  5. "High performance" petrol is needed if it is needed, so to speak. I run my Beta on V Power as that cured the rattling under load on a correctly set up motor. I certainly would not be using it otherwise.
    yep the 2000 Sherco 2.9 I had ran best on 93 octane "pump gas" 110 octane race gas had no positive effect on it.
  6. Sting
    Take it one step further and figure out that E85 being 85% ethanol and costing pretty close to the same as regular gas with the 15% ethanol. You get even less MPG from a gallon of fuel than you do with the 15%. but the government and the auto industry push these Flex fuel vehicles as great gas savers. Sure they save gasoline but you spend more $$ to do it.
    In my opinion it is all a big shell game and somebody at the top just keeps getting richer. I have no problem with people making money, or even being filthy rich. But I have a problem when they do it by lying, cheating and basically pulling the wool over the eyes of the consumer.
    Sorry I kind of went on a rant there
    I use 80:1,race fuel 110 octane in my new to me 2003 Gas Gas 300
  7. Welcome to the WONDERFUL WEIRD WORLD OF TRIALS!!!! yes you should have done it sooner, but now that you have you will certainly enjoy yourself. One of the best kept secrets of trials is how much of a full body workout it is. One would think I would be thinner though................. must be the :beer: afterwards......
  8. I would bet the water pump seal got hot when the motor overheated and was dry with the shaft spinning in it and that caused the failure. It would be like a secondary failure attributed to the original failure of the hole in the radiator. Same reason the piston got hot, seized and needed to be replaced.
    I think the water pump O-ring they replaced is for the water pump cover sealing to the case and has no affect to the water pump shaft seal which would leak into the gear box. Check out pages 64 and 65 of this manual parts numbered 3 and 4 in the exploded view on page 64
    http://www.trialspartsusa.com/manuals/Despiece_TXT_Pro_2008.pdf
    I just recently purchased a 2003 Gas Gas 300 and am trying to get familiar with the motors and where to get info. So far I am very pleased with my choice to switch from Sherco to Gas Gas.
  9. Really ?/
    2009 Gas Gas Txt Pro 280 Cracked Frame
    http://www.trialscen...ing-frame-this/
    http://www.trialscen...-frame-problem/
    UMMMM the Exception that proves the rule? :dunce:
    I did see that in the other forum I was hoping it was a rare occurrence. I know Sherco had frame troubles at one time, I know a gent that had to get one replaced. And Gas Gas had swing arm problems, saw video of rider doing a drop off and on landing the swing arm snapped into two pieces. But my point was Generally post 2000 bikes handle these things better and have better suspension etc.... but I also mentioned "Also you probably already know that the harder you ride a bike, the more stuff you will need to fix later."
  10. TY 175's are great bikes and great fun. When I was a youngster I would jump the bike off the top of a hill and land about halfway down. (hill looked huge to me at that age) older brother would land at the bottom. so the landing was angled on the hill, I assume not as much stress as landing flat. We never cracked swing arms that I know of. Dad did the maintenance. I did bust a foot peg mount on the TY80 I had before the TY175.
    But you must bear in mind like the other guys have said, The twinshock bikes were not designed for the more "extreme" steps and ledges that the post 2000 bikes will do with ease. Also you probably already know that the harder you ride a bike, the more stuff you will need to fix later.
    The motor is about bulletproof, and they are a good handling bike. Check out the twinshock and video forums on here or search Youtube and see some videos of others riding twinshocks and you should get an idea of what those bikes can handle. (one tip to remember if you watch "world round" twinshock vids, those guys were/are very very good riders) You may be able to find a post 2000 water cooled mono in decent shape for close to the same $ as that TY175. I don't know about prices and availability in your area.
    I also think scmbud being new to trials was asking a legitimate question of technique " Will she be cool if I huck it off or should I go slow and drop the nose down before letting the ass follow?" I think hucking it off the step would put great stress on the suspension and swing arm like the previous guys have stated. Depending on the ledge/step letting the front tire drop down first may have you going over the bars if the front wheel "tucks" under. So if you go the route of dropping the front tire first keep your butt as far back on the rear fender as possible, so your weight does not carry you over the handle bars when the front tire hits the ground.
    As for my comment on spelling, it was made partly for humor (suck them in with kindness and then get them on grammar. I have an odd sense of humor) and partly because I was able to decipher it pretty quickly, I also have seen posts from other countries that I had to read 3 times or more to understand because it read like it was sent through google translate to get it into English. I agree that text speak is banned from TC, but there is the occasional "fat finger" typing that gives bad spelling.
    • Like 1
  11. the 2000 sherco I had the non vented disc and the front caliper was a 2 piston type, it had horrible stopping, so I bled the brakes multiple times, changed pads, new brake line, rebuild master cylinder and clean disc with super super fine wet sand paper (2000 grit?) then blast hell out of it with brake cleaner. When I finally rebuilt the caliper (new seals/pucks) Front brake was great.
    On a side note because the disc was non vented I cut an angled groove in the brake pads, using a dremel tool and 2 cutting discs installed to make it the right width and get a sharp edge on the pad. My reasoning was this groove would give someplace for water, dirt, gasses, and whatever someplace to go instead of between the pad and the disc. I have no proof whether it did what I thought or not. but it didn't hurt either.
  12. Obligatory name dropping time......... I know and have ridden with Aaron and Yuki both have been members of MOTA. Yuki moved for work/school and I don't know if he still rides. Aaron has been working on his house and it is looking AWESOME, I hope he returns for the 2013 season.
    I saw Chase at the combined TI / MOTA event in Indiana, He has grown a bit since that video and has improved his riding even more.
    Sadly I have not met Ryan, he really seems like a fun and down to earth guy to hang out with.
    (whole purpose of this post.............I got to post and be part of the conversation. I was like a politician said many words, but did not really say anything)
    • Like 1
  13. Well....I too like the "stock bike" approach. But I do not understand the stop/no-stop debate.....to keep from p***ing one group off...why not mix it up? Have a mix of stop allowed/non-stop sections at each event....fans could gravitate towards their likes....and riders could always be afforded a few of their preferred sections. Compromise.
    OOOHH imagine the drama when the top riders can't remember which sections are stop and which are no stop. And the minder(s) tell them the wrong one!!! :dummyspit: That could be a joy to watch.
  14. Amos Bilbao has suggested that riders not be allowed to argue with observers, period. I think this is a great idea.
    This thread was intended to fire people up about the upcoming World Round at TTC.
    A long time ago....... As a young lad I was lucky enough to spend a summer working at Sandiford's. I spent my time along side the great Bill Brandwood who taught me so much. I recall that the was a Brittish Round of the MX GP 250 coming up nearby and we all made plans to go. As the GP grew near ol' Bill began a countdown every day he would remind us that were we going to see the greats of MX ride in anger. He'd say "just 2 weeks, boy until f#cking Grand Prix" !! He was so stoked and it spread to the rest of so much so that buy the time we got to the day of the GP were we all going nuts. We spent the day leaned over the ropes cheering on the greats of MX . The late great Jim Pomeroy raced that day. He crashed early on, came around in dead last with no visor or goggles and worked his way back to to fourth. My memory has never been great but that day stands out.
    Why tell you all this story.? Because all this talk of rules changes has got us here in the US missing the point. It's been 5 years since most of us have seen Toni Bou and Co ride. Seeing him ride on You Tube is not good enough. I want the real thing.
    The idea of No Stop has trials riders talking about the state of the sport and that is a good thing. But its a bit like politics or religion. It has the potential to become polarizing. This post is intended to get people fired up about going to TTC and remember it's just 6 months to the US World Round!
    I like the suggestion of no arguing with the Observers. best way to keep observers. (note to observers please be fair and consistent that is all I ask...... that and accept my bribes for cleans)
    Good point about being able to see the best riders in the world come to our country!!!
