as long as there is fluid in the master cylinders and not sucking air into the lines you should be ok just topping off the fluid and putting the covers on.
Are you having problems with the front brake/clutch currently? or have you just noticed fluid level in the window is low?
It is always great fun when you "click" with your bike.
About the cramped feeling of being too close to the bars. 2 possible solutions. Buy a set of taller bars and/or bar risers. Or shorten the width of your bars (I will explain) The following is merely my opinion and what worked for me.
Get on your bike and hold onto the bars. Look at your wrists. Your forearm and hand should be in-line with each other. If your bars are too wide the back of your hand will be pointed in towards the center of the handlebars. Keeping roughly the same bend in your elbows Slowly bring your hands in toward the center of the bars. (this may may be a small amount like a 1/2 in./ few mms) until your forearms and hands are in line. This will reduce stress on your wrists as well as move your upper body back a little bit, easing the tension on your back.
Being comfortable will also improve your riding and then you will feel just like Toni Bou, or if you are crazy enough you could feel like Fujigas!
OK update. rode the Reflex to my brother's house. He has the drill bit (.016"). remove carb from hot bike. that was fun. Drilled out the pilot jet using bit, hands and pliers to hold the bit. Reinstall the following parts: pilot jet, baffle around main jet, oil breather/separator, snorkel in air box. basically returned the bike to stock with larger jets. Air screw is at 1.75 turns out like book states.
I left my brother's house and bike spit and sputter before I even get into 3rd gear. I ride 3 miles hoping it will just "sort out". No such luck. pull over to side of road and remove the snorkel. (I took my own tools with me) Ride the rest of the way home NO sputter, bike revved out pretty cleanly. I swear I even saw the speedo needle point at 56MPH!!!!!! I am going to call it fixed. I guess it will just be a bit "throaty" in sound.
THANK YOU EVERYONE for all your help, and suggestions
' can't explain why but I had to put it on reserve 10 miles earlier than I ever did before. '
'Cause you actually rode the thing WFO for a while !!!! ???
Glenn
And interesting lunchtime video entertainment !!!
Everytime I ride it now it is pinned WFO!!! problem is WFO = 53mph
We at Team WGASA may not be the best trials riders but we are very entertaining.
And our event last weekend was at a ATV park ... The LITTLE kids on 400cc+ 4x4 quads with no helmets and flipflops on kinda scare me ...almost as much as the adults? on the loud baffle less ones (also helmetless and flipflop ...)
But a 50cc rigid class for trials riders would be a ball !
OH Lord don't get me started on the F*****G Morons that won't wear proper safety gear, act like idiots and let their kids ride on machines that are WAY too big physically and motorwise for the kid. Also without proper safety gear. These are the people that non-riders remember and these are the idiots that are requiring stupid laws about off road riding.
You go up on the pilot because it comes lean from the factory. Needle is non adjustable and if he wants to spend money there are several threads on other needles. At this point I would look at a larger cs. sprocket and in the future an adjustable cam chain sprocket which is only 20 dollars if you like a little work.
Have seen posts where people have shimmed the needle. Worthwhile???
I am trying to avoid spending money because......well I am cheap that's why.
I plan on drilling the pilot jet and returning the snorkel to the airbox. Not really liking the new sound when I open the throttle. I miss the whisper quiet Reflex I had. I also suspect with the snorkel out my fuel economy went way down. can't explain why but I had to put it on reserve 10 miles earlier than I ever did before.
try a new coil ht lead and perhaps a plug without a resistor if there is one in the cap you possibly wouldnt know ,, symptems sound more like its lean top end though and removing snorkel could make it worse which could point in right direction ,, cant see the issue been the pilot , have you tried lifting or dropping needle and what is plug colour
Oddly enough after removing the snorkel I have ridden it 4 times and only had 1 sputter. Plug was white and chalky originally, drilled out main jet and then plug was a decent brown color but still spit and sputter. Then I removed snorkel. Have not checked plug color after snorkel removal. Still plan on drilling pilot. going with a #78 (.016") because my brother has that size
You guys do realize how event attendance would triple if you had a Quad class
Running over your own flipflop is likely a 5...
Those of us that are members of Team WGASA have ridden over ourselves before, we know how to 5 with style!! Not sure how a quad class would work out? not much balance there unless needed to go 2 wheels around something. 6ft splatter with a quad?? interesting.
good video Zippy and it's good to know that Biff's footwear has a sensible name there - they are "Thongs" here in OZ and I think in New Zealand they are "Jandals"
Kinda like how sticky tape here is called Durex and the most popular beer in my state is called XXXX
Thongs here are a type of, let's just say, minimum type of undergarment.
Durex over here has a closer connection to XXX (not the beer) than sticky tape does.
Alrighty, I removed the "tube things" from the airbox. There was no spit or sputter on the way to work and only 1 on the way home. I thought she was a bit loud on the intake before but now there is a very loud deep throated BBWWWWWAAAAAAAA when the throttle is opened up.
And this bike is being run at WOT for an 8 mile stretch which equals a top speed of 53mph
I do plan on drilling the pilot jet, probably today. With the hopes that I will reach 55mph
I had one in my '85 Yam 80 quad
I got one of those quads, no suspension, 4 speed, no clutch. mine is of the '85ish years YFM80 MOTO4. For a laugh watch this video. Biff is shirtless and wearing flip flops. I take the quad back and show how it is done.
Lineaway does this sound familiar "(#77 drill bit) .018" would be equivialent to something between a 45-48 Keihin pilot jet size" Found in the Thumpertalk forums, (gotta give credit ya know)
Lineaway, thanks maybe some googling and I will find what size hole Keihin 45 and 48 jets have in them. While at work I was thinking about that pilot and was beginning to think that the main supplements the fuel to what the pilot provides. So I was thinking they work in conjunction of one another.
mcman56, yep I had the bike stripped of lights and used it as a trials bike for setting up sections for Beginner and Novice classes. Never really revved it up, so did not notice this problem at the time.
Yea, sell you my XT 225 Serow for 2K, come get it!
You have said that Serow is a fun machine to ride. But unfortunately it would cost me about $2000 in fuel just to pick it up. A hard sell to the little woman. Now if I could somehow get some riding done and a family vacation out of it........Nope still won't go over well.
I know you probably have but double check your timing , to much advance can do what you describe too. It is a pain to do but you can check one with a light at upper rpms . May take 2 people to get a accurate view thru the little timing mark hole ....
Have fun nonetheless...!
Actually no I have not checked the ignition timing. this thing is not adjustable. But checking the timing would help diagnose if I need a new CDI for it. HMMMM may have to check into this. Book says I need to hook up a tach along with the timing light. any way of being relatively accurate without the tach?
I alway like to say "Check yer grounds" on crap like this,ignition to engine,engine to frame,coil grounds,ect.
Not familar with Refluxes but if yours has a battery that could cause issues if it's bad. Does it have a resistor in the plug cap? Seems like I remember those causing problems in old hondas.
P.S.My buddy Bill just bought one of those new Honda dualsport 250s,getting 80mpg right outa the crate...Looks cool,runs smooth(Fuel Injected),pleasant to ride,shifts perfectly,and dirt cheap!!!!under 5k out the door...Bill has a couple of Reflex he could be street riding too,prefers a little comfort instead
Battery is new this season.
no resister in plug cap that I know of. ( I also took cap off and trimmed wire and redid connection, same result in running)
I may need to go over the grounds again.
I am too cheap to spend around 5k, already got the Reflex.
hi, your mains been drilled out to 1.00mm.....which equates to a 102.5 keihin main jet, so should be plenty. lineaway is right in saying the standard air box is restrictive. sure i read somewhere also that the ignition curve is not very good for top end running, and a cheepo pit bike cdi box helps. try the simple things first though.....
any idea what cdi box to look for? If I need to go that route.
S_hit, give us a hard one next time. The pilot is too small, hard to find also. Adventure rider trials forum had a thread about cb400 jets. I `m inpatient. Drill it!! Also a larger CS sprocket can`t hurt. The air box needs all that silly stuff on top(the plasic looking pipes) removed they come right out and can be re-installed. The main could still be too small at your elevation. Seemed I had a 100 at 6000ft. If your main jet is as large as you say, try the air box first. Good luck!
Would the pilot have anything to do with high revs? It idles and performs well at low RPM.
What size bit should I drill it with?
I went from a 10 tooth CS sprocket to a stock 13 tooth.
OK I am very frustrated at this point. decided to use my 1986 Reflex as a commuter bike for work (11 miles). Yes it is about as comfortable as a tack on a 2x4 set edgewise but 65 mpg is cool.
Problem is at high revs any gear under load and also no load, it spits, sputters and does kind of a backfire thing into carb. Really annoying at 50mph and in the dark when it stalls.
I have thought fuel issue, carb is CLEAN!!! (many times) tried various settings for air screw. Float adjusted so there should be enough fuel in there to drown an elephant, but not coming out the overflow pipe. Tank filter is clean and new inline filter. Jets are stock 38 - 92 but the main jet has "accidentally" been enlarged to 1.0mm
New O-rings on intake pipe both ends.
I also replaced cam chain and guides and rings. I initially thought the cam chain was the problem. Valves are a pain to adjust, that .002 of an inch is hard to get.
I have the shop manual, so it tells me how and what values to test the electrical things like rectifier and such, but I need to buy a new meter.
New plug NGK DR8ES "for extended high speed riding" before that was a DR8ES-L I thought maybe the old plug was too hot and cylinder was overheating.
I am going to try removing the baffle around the main jet. Stab in the dark as they say.
Thoughts, Opinions or just some witty remarks to help me out??
On older Sherco's head did not need to be removed but coolent needed to be drained. I assume on a 2010 the head does not need to be removed, but I am unsure how the coolent is routed in the new motor. Probably will need to drained.
I have done my fork seals many times.... ..wait that makes me sound like I don't know what I am doing. Anyways I had issues with internal parts braking and rubbing together making metal shavings and a knick in the tube etc.....
I think you have the same forks I do. Both sides have the same internals. There is a dust seal that you pry up with flat blade screw driver and then the wire retaining clip and under that is the fork oil seal.
I got all crazy and bought a spark plug socket and took the old socket and with a dremel cutting disc cut off the hex end of the socket. Now that hex end fits in the top of the fork cap and also my 3/8 drive ratchet fits in the cut off hex end of the spark plug socket.
For a fork seal driver I use a chunk of PVC pipe, off hand I forget the exact size but I think it is 1 1/2 but measure first before going off my memory. I used the dremel to round off the end of the pipel
(Sure glad I bought my wife that Dremel for her birthday )
Hi All
in Introduce Yourself
Best thing you can do is go practice with friends, especially ones that ride better and are willing to "push" you a bit (and pick you up afterwards)
Let me know how you get the bike to come down from the tree without breaking things, that would be a good skill to learn.
Plastic ties and a drill bit could "stich" your fenders back together, depending on how badly broke they are.
