I know it's a pain but I guess the AMA has had some lawsuit problems with a child getting hurt and the other parent filing suit because they did not approve of the activity.
Brockaway,
OH yea the book that i should have read.... DOH!
Zippy,
Dont let the mrs know that her prior consent is required and if she wants to sue tell her to sue me. Im broke so no harm no foul there....
Kjax,
Dont tell zippy yet but my plans have changed as of about 10 mins ago. Were riding over at Kutchey's tomorrow. Come on and hang!
Contact Mike at the Trials Shop in Locke , NY. great folks and a lonngg standing trials shop ... I'm sure he can tell you anything you need to know and /or supply any bits you may need while here !!!
Glenn
He also has some great water falls in the back you can ride on....
Yes your correct you will be driving but once your outside of new jersey and past the deleware water gap (on interstate 80 and no you cant climb it but you will want to. sorry new jersey!...) or north of the nyc region into conneticut, the terain is awesome.
Pic of the delaware water gap for those who don't know... i cant help but to want to ride this some day.
If you go to their website it does not look like they make this any longer but they do make an interesting looking full size electric mx bike. 25 electric horse power, Ohlins shocks and stuff. Seems like they do a lot in shop as well.
If you google them you will find this.
www.electricmoto.com
A quote from their website "In 1997 we became Denali Cycles and brought to market the first production high-performance electric powered off-road cycle, The Moto Pro."
An interesting note is that their stock price is $0.00001 (according to the link on their website). You can buy 5000 shares for 10 cents. Take half of your paycheck and perform a hostile corporate take over....
I highly doubt you can ride much above the junior class....
Bring on the SEASON!!! i am stoked.
Hey i have not been paying any attention. The release form that i had noterized, blood drawn for, sealed in a circoficus, then sent out to ama.... I have not done that yet this calander year. Do i need to get anything done before your event Sam?
Your centrally located between several differnt clubs being in the nyc area.
No organization is really in the ny metro that i know of however your close to several differnet organizations.
http://members.dmcom.net/~3dtrials/ This is 3d of eastern new york but upstate from where you are at. The catskill mountains has a great event about an hour or two from you.
http://newenglandtrials.org/ These guys ride all over the new england region (new york, mass, conneticut, vermont, new hampshire) Some of the events in conneticut would not be too bad.
http://www.durtydabbers.com/ These guys ride in the district six pennsylvania area. I couldnt find their schedule but for the durtydabbers are a great bunch and will be able to help you out.
The next two places closest from these are northern virginia
You might be able to find a huge following of trials bicycles in the nyc area but not much on the motorcycle end. Long island used to have a crew but land is sparce out there.
Yep i can attest his sherco has grunt back! Runs and starts like a champ! We had a blast riding for a good solid 3 hours falling on our a$$es. I still think that he needs a 4 piston front caliper. We swapped bikes at one point and zippy went over an off camber log on a muddy bank and grabbed a bunch of my gasgas's front brake (which works like a champ). Went right down on his head. Very amusing.... It was too cold for any video devises unfortunately. (high 20's)
In the past i have slipped an o ring between the cuped washer and the disc to quiet them down. Looks a little cleaner than silicone. It is ment to float.
As i recall the compression release in the cota was a second hole in the head correct?
Generally these were used to reduce compression for ease of starting. Most people put a second plug in place of the release as a backup.
On my yamaha enduro bike it puts compression gasses from above the exhaust port via a small hole into the exhaust. Running down the road the only thing i got from it was lack of power at higher rpms. If you leave it open too long there is the posibility of running lean and sucking in dirt with the head plug version.
Sorry Cope i never got to it this weekend. I was busy working on my Greeves/tl125 project. I started welding and brazing and just couldn't stop! hahahaha. If i find a free moment i will get some scope readings. Just wanted to let you know that i have not forgotten.
"My roommate worked very closely with borg warner with their torque on demand system. You guys have a similar system on jeep. He has a montesa which are known for their clutch drag. As it turns out chain tension and that really expensive stuff was the answer to his problems."
I am not quite sure what you are saying here, is he using the transfer case fluid? or something? And yes, we have different fluids that rely upon progressive or modulated clutches to apply power(hopefully smoothly) and I am not sure what additive packages they use. There could be a LOT of experimentation there, more than I would like!
Oops forgot to finish my point.
A lot of techs out there have played with friction modifier in their tcases to try and get awd shudders to diminish. They end up taking out clutches or causing chatters and engagement periods to be more harsh. My roommate tried a few different mixtures and ended up with no clutch plates after a while. He finished his experiment by getting a new clutch and tightening the chain using the specified oil and wala it worked like a champ.
Becareful because this might make a good day of practice a long day of walking around. There is a lot of science in those fluids. Besides i thought that sherco clutches were flawless?
First; Spark.... Have you ever measured dwell off of your coil with a scope? Come on now i know where you work and some of your resume. Change plugs look at dwell. Change mixture look at dwell. Increase and decrease gap look at dwell. Get out your gap spark tester and measure. (doubt you have room for that on a sherco but its a thought) You bring up a good point here and i think you might find some answers in dwell. Tell ya what. This weekend I will grab one of our IDS's and a VMM here from fomoco and take some screen shots of what i have on my 04 gg. I am not sure if you have capability of something similar but this is interesting to know whats going on in there.
Second; friction modifiers... My roommate worked very closely with borg warner with their torque on demand system. You guys have a similar system on jeep. He has a montesa which are known for their clutch drag. As it turns out chain tension and that really expensive stuff was the answer to his problems. I use straight dexron and change it ever 8 hours or so of ride time. One night before an event i needed a quart and some turbo blue for the bike. I thought i would kill 2 birds with one stone and picked up a quart at the station. When i got home i looked at the bottle and i kid you not it stated "Almedes Oil Company" and it had no sae markings or anything. Due to my lazyness i threw her in so i wouldnt have to make two trips. Smelled like 80-90gls, was red, poured like 30 weight.... In the morning i drained it in fear of the unknown. Becarefull because the sulfer in friction modifiers (such as dana 60 70 or 80 additives) can set permanently in clutches and cause too much slip and its hard to get it out of the fibers once its set in.
I am part of the fuel injection generation so i would be real interested to hear the carb setup edition.
I am going home to shovel some beautiful michigan snow now.
Had to leave 84 degree tampa to come to 25 degree detroit last night but we will suffer.
Every body is jealous of the tans which is a plus.
If you have the means next year come down from the north you will not be disapointed. You can be sure that we will rave about it up here. Great challange and if its not for just the great weather you get to ride trials with a great group of people. Thanks again!
This type of information should be posted in the newly created "USA Trials Reviews and Previews". I don't think many people know this Regional Series exists. Some of the funds go to support our TdN team...which is great, but why such a secret?????? (just trying to make a point).
Have fun down there!
You are correct I will see if andy or atom can move it for me.
While surfing the Florida trials website I realized that the fun in the sun will be part of the south eastern regional series. As I recall from last year one was held by florida, one by stra and one by trials inc? I can't find any info about if this is the same for this year.
Does any body have any details? Thanks in advance.
Snowbirds! Look at that snow, that is just sick! It was about 80f here today!
And if I had to say, someone needs to tell Biff not ot put the whole bike in the powdercoat oven! It seems kinda harsh on the rest of the plastics and gas tank! It could explode!
Man cope you set yourself up for this one.....
Its a SHERCO! Chances of explosion are high regardless of the oven being present or not....
My maita got stuck in his driveway on the way out. Its amazing how much mud and snow act the same. Good cross training.
Jim,
Sorry we took over your post. I have been meaning to tell you. I went to lake placid to go skiing the other week and got really sick. Didnt hit any of the snow. Your vid makes me jealous. I spent major coin for nothin. My girlfriend had a good time so i had that going for me... Michigan has lots to be desired in the skiing department. Being from upstate ny I was spoiled at too early of an age.
I feel fortunate to see you riding at such a high level in such a short time.
It will be tough but we are behind you over here. I know its just craig's speculation that you will be upset about this but you royally kick a$$. Nice job.
Mota 1st Event In Indiana
in USA Trials Reviews & Previews
Brockaway,
Zippy,
Kjax,
--Biff
