- Fan
Running Rough!
hi i have a 1993 jt 250 that only runs well wen the choke is on turn the choke off & it runs like a bag of spanners,it also takes a while to start even though it has a gud spark,the plug is always wet through any help wud b great
Torque Settings
hi i need torque settings for the cylinder barrel nuts & cylinder head bolts for a jt 250 1993 cheers
Jt 250 Engine 1993
there is no overflow pipe on the header tank its just a small nipple type thing
Jt 250 Engine 1993
hi im gettin water in my gearbox oil is this down to the cylinder head,after about 5mins running all the water is gone & ends up in the gearbox its also getting hot cos i dont think the fan is working wat temp should this kick in is there a way of checking this
Exaust Packing
hi i have a jt 250 wiv a sealed exaust which is very noisy how the hell can i repack it short of chopping it up,does anyone now of any kind of universal exausts or where i can get a replacement??
Won't Start
Hi cheers 4 that ive had the flywheel off & tinkerd abit & the flywheel key luks ok but i noticed the key doesn't stick out very far anyway i put it all bk together & 3rd kick it started but only ran 4 bout 30seconds so i tried again & its bk 2 backfiring again so i think the flywheel could be slipping rnd on the key.
Won't Start
Hi my jt 250 won't start it just backfires every 5th or 6th kick,anyone help
- Clutch
Clutch
Hi folks i can't seem to bleed my clutch up on my jt 250 ive checked the clutch pipe & its clear(no blockages),ive put a new plunger in the master cylinder as the seal had split,i just cant seem to get fluid in to the pipe & down to the nipple to bleed it,the master cylinder is also clear,can anyone shine any light on this
Fan Motor!
hi does anyone know of any breakers as im after a fan motor for my gas gas jt 250 1993,any help would be great cheers
- Oil !
- Wireing!
- Wireing!
Gas Gas 250
hi ive just baught a 1993 gas gas 250 in need of some tlc,first off there is a milky oil dripping out of the crank case breather wen running is this the crankshaft oil seals,also were do i get parts for this bike such as body panels & mechanical,cheers
gasgas1
