phonomenon
11 -
Hi So its come the time to put it all back together and hope it runs, does anyone know what torque i should do the flywheel up to?? Or would using a half inch gun on a compressor be enough?? Cheers J
Hi Thanks for the advice. The timing was ok when it was running so id better mark it up well!! Just waiting for the postman to turn up with my puller and i will get it off Cheers
Hi all Firstly i would like to thank all of you for all the advice you have given me so far!!! I have come to the conclusion that i need to get my stator tested profesionally as i cant be 100% sure that im testing it right! So i have got the cover of and found a nut lol can i safely remove the flywheel using a puller without mucking up the timing ect ect??? Or is the some sort of procedure that i need to follow?? As allways any advice will be apreciated!! Thanking you all in advance J
Hi Yeah i called Motoplat and he told me to get a multimetre and put the green and white on the leads, He said that i should have a reading of at least 400ohms which i do! So god knows whats going on. BUT since nothing makes sence i have decided to take the stator out to see with my very eyes that its ok! Will let you know how i get on J
CDI Unit, I asume you mean the ignition coil? If so i have bought a new one and fitted it and still no joy! This is fast becoming very frustrating! J
Still no answer, I have tested the stator and its giving out power to the regulator but still no spark! Today i fitted a new ignition coil hoping that it would solve it but still no sucess. Does anyone know what each colour on the stator is meant to do?? also could the regulator be causing a problem??? J
No mate im not him, at least im not alone with this problem! J
Hi, Would anyone have a wiring diagram of the 1995 techno that they wouldnt mind sharing??? J
Hi guys, Was out on my beta when all of a sudden it just died on me, Tried starting it but nothing there! Its getting fuel but no spark. My first thought was the Coil. Does anyone know how i could test it?? Is there anything else i should be taking into consideration?? Ive checked all the connections and they seem ok and it recently had a new spark plug. Any thoughts or ideas would be apreiacted!! Cheers J
Hi Thanks for the feedback. good to know that im on the right wave lengh at any rate.... Will let you know how i get on once i have the seal Cheers J
Morning guys & gals Just getting into this great sport after trying my friends Scorpa a few weeks back.. Bought myself a 1995 Beta Techno. Starts and runs lovely but it seems to have a nasty oil leak. I can see that the oil is coming out of what i would describe to be the layshaft/output shaft?? (the shaft that has the rear sproket to what the chain runs on) Sorry for the basic tech talk, hopefully it will improve with time. Am i right in thinking that i can untension the chain from the snail tensioner, remove the chain & sproket & replace an oil seal??? Also is there anything else worth replacing while im there such as a bearing??? I have most hand tools at hand but have never really done much work on a motorbike before so any help or suggestions would be apreciated!!! J
