luke7129
    16
5,626 profile views
  1. @Tr1AL I did come across one last year which was in bits but all there but unfortunately I couldn’t afford it at the time, I do like collecting spares though
  2. Hello @Tr1AL I have seen them thank you very much but unfortunately it’s wrong year bike so the parts I need aren’t interchangeable
  3. I have already gave him a try. Thank you though
  4. Is anybody breaking a 1991 K Roo? I’m after some radiator plastics and radiator cap shrouds. Thanks Luke
  5. I wouldn't mind seeing some photos, but im in the UK so shipping would be rather expensive unfortunately. Thanks anyway
  6. Do you have any photos and where are you located. Thanks Luke
  7. Hi guys I’m after some advice my friend has just got a 243, it would only run on choke to start with and was constantly spitting oil out of the exhaust. We have replaced the crank seals and o rings and give the carb a thorough clean, but it still won’t tick over. Does anyone have any ideas and know the carb settings? Many thanks.
  8. Thanks guys I shall give them a try!
  9. Hi guys I have recently got hold of a 1995 Fantic Section 249r. It is not on the original engine because the previous owner will and truly ruined it so the new one is date stamped 94. After a few electrical problems I’ve finally got it running and the engine is sweet however I run it to see if the fans was working but it doesn’t seem to kick in. I’ve had the thermostat rethreaded into the top of the cylinder cos someone had ruined the threads. Is there anyway of testing the stat or fan to see if they actually work? Many thanks Luke
  10. The exhaust is as clean as I can get it, I give it a good clean and repacked the silencer. And I always clean the air filter every couple of trials
  11. Thank you very much guys ?? I’ll get the carb to bits and see what it’s actually running on.
  12. Hi, I was after some advice please. I have fantic 245 with a 301 motor in it but the plug is always blacking up. Any suggestions on carbs and jetting? Thanks
  13. Thanks will give it a try, also what should the carb set up be as the plug is always black and dry after each trial. Any tips? Thanks
  14. Thanks guys, im not that clued up on engines what will this tell me? Thanks
  15. Hi was wondering if anyone could shed a little light on my problem i have a 1986 honda tlr 200 relfex, the bike runs and starts fine but when it gets hot it starts to rev up on its own and they dont die off, i have tried 2 new carbs and i still have the same problem. Am i missing something? Thanks
