As per pictures below, I have fitted engine (which is offset to give clearance) - and have widened swinging arm. Ive got the rear hub in what I think is the correct alignment measuring as best I can, I can then measure to get correct spacers manufactured.
Is there an easy way to check front to back sprocket alignment ?
cheers
John
Cheers dave
do you have a contact number ?ive searched on internet but cant find
cheers
john
Hi
Ive covered rim size on a previous post, but thought I would ask the remaing (at the moment) questions in one go
1 - Sprocket size
Its a 4 speed engine - unsure of any internal gearing changes. What the best combination of sprocket sizes ?
Also- chain, 428 ?
2 - Wheel offet
Im about to get new rims built onto bantam hubs
Rear (using a widened swinging arm and engine offset 8mm) - I think needs no offset ?
Front - I think 6mm offset to brake side ?
3 - Chain tensioner
Any advice on best type ?
may think of more !
cheers
John
Me and my son are planning on riding as meany of the events as possible. I emailed to ask about the possibility of a youth class (probably within the clubman, open to maybe any A B or C class rider ??). I got a positive reply saying great idea, encourage youths into twinshock/classic etc
So........come on, get your sons/daughters to ride with you and support the series !
cheers
John
Cheers ! Know the 21 and 18 inch, just wasn't sure of the rim width
John
Quick question
buikding a bantam at the moment, whats suitable rim size (building new wheels)
cheers
John
Just bought a frame kit from progressive. Very helpfull, looks well made, would definitley recommend
cheers
John
I brought my son on that way whos far better than me now (hes just gone 14, we ride trials together albeit twinshock and pre 65 now but we still do modern trials in the north east)
To be honest, richmond club are great with kids on conducted then beginners easy on the main route (where you can ride as well)
A couple of weeks ago we ride a guisborough trial and there seemed to be a lot of kids on the conducted route (we rode main trial)
Either of these are great routes to start on then any north east easy trial will be good for both of you
cheers
John
Latest latest update - contacted the guy I bought it off and he had a mikuni 26 built with standard 175 jetting. Going to try a 175 carb I can borrow just to be sure - but may just need more cleaning ! (Ultrasonic ?)
Cheers
John
Update .... On cleaning the carb found out it has a 125 carb! Trial at the weekend was significantly better, however still not running right - now bogs a little under power ... 175 carb the correct route ??
Cheers
John
Thanks for all the info and help.
easy things first, as mentioned above a good thorough carb clean first...
cheers
John
Thanks for the response guys
Reeds seem OK (no gap) - but might be worth changing anyway ?
Just been stripping it down and a quick question - the inlet rubber onto the reed valve is offset (to the left hand side of the bike) by a significant amount and does not line up with the reed valve - is this normal ?
cheers
John
Had a problem with my sons TY175 today.
Was running great 'till a very wet New Years day trial, where is developed a bit of a cough and splutter.
Airbox was soaked when I took it apart, so cleaned the airbox, replaced the filter with a new one (probably needed a change anyway) and cleaned the carb. Nothing obvious in the carb.
Next trial out was today, where is had a distinct 'bog' off the bottom when opening the throttle. Also after stopping was really difficult to start.
The 'bog' was so bad that riding through a section, seemed ok but then on the uphill exit, it just died (almost like you had left the fuel tap off).
Decided to call it a day, again difficult to start (and had a little backfire before it did start again). When ticking over, open the throttle quite quick and it just dies.
Running electronic ignition.
Any ideas ?
Was planning to clean carb again , but any thoughts welcome
cheers
John
As Gordon says, Butsfield is a vmcc event, the land kindly offered by consett club which is great. Not really a conflict other than for a handfull of riders (me and my son included)
one things for sure, you can pretty much guarantee someone will do their very best to puut a trial on
cheers
John
Hi there
Some of the local North East clubs do conducted route which runs separate from the main route, this is what you will need. It really depends upon interest, but all north east trials are advertised on TC, just give them a ring.
Richmond club definitely run conducted courses at most of its trials which are a great way to learn. This is how my son learned, its great for the kids
let me know if you need more info
cheers
John
Hi there
im in chester le street
Trials every weekend in the north east, in the summer choices of saturday sunday and wednesday night !
my advice, go to a locsl trial, then enter one - best and most enjoyable way to learn !
cheers
John
Hi there
my sons bantam which we got a few months ago is a 3 speed. I was a little worried that it may have been a bit higher geared, however it is fine with 14 tooth front and 62 tooth rear sprocket. It will run on tickover in a section no problem and pulls well.
cant comment on longevity as we havent had it too long.
cheers
John
Thanks for info !
I've ordered electronic ignition anyway, then going to step through carb etc
Cheers
John
Hi there
Im after some advice on my sons Bantam
It has a D7 Engine, standard Amal carb and standard style Air Filter. Currently it doesnt have electronic Ignition.
We have only had it a few weeks and took to first trial today. Up to now its been tried out in the street with no problem.
First couple of sections if was fine - then started to bog badly when opening the throttle - also a bit of backfire ?
Got to the point it was difficult to ride was boging so badly. Changed the Air filter for a foam one I had in the tool box but the problem was the same.
Got home and after an hour or so on the trailer, fired it up and it ran spot on (albeit only for a few minutes).
I do intend to fit electonic ignition anyway (electrex world probably, I've used them on a few bikes with no problem), however any more advice ??
Many thanks
John
Hi dave
did you get start time and directions
cheers
john
Hi Dave
I think the last one was a Saturday - so start time moved ?
I'm assuming 11am - but if you find out any different let me know !
cheers
John
Vmcc south durham run 12 trials a year for pre 65, around north east. They are never advertised on TC, normally in TMX and on their website.
Good trials for pre 65
cheers
John
Hi Dave
Do you mean the vmcc one at underbanks next week ?
Cheers
John
When i had one it had a backfire, but didnt fiddle as it ran well and wasnt a problem.
only time it caught me out, it blew the carb boot off during a trial! Didnt realise as it was just off (couldnt tell) , wouldnt start, long push back to the car. Realised what it was when I got home, and was just happy it wasnt high expense ! So check jubilee clip tightness .....
cheers
john
