notaddicted
    3
  1. You are correct it is a monoshock. Looks like a trip to Halfords is needed. Are you sure it is 14mm? I measured an thought it was 12mm but I could be wrong. Thanks
  2. With regards to taking off the front wheel, can anyone suggest where I could obtain the tool to do this? Thanks
  3. I've recently resurrected my old TY250r. After cleaning out carb thoroughly and replacing float valve I took it out for it's first ride today. The engine appears to be racing quite a bit. I've adjusted the throttle idle screw so that it is ticking over nicely, but when you pull the throttle it takes about 10 seconds to get back to idle speed and sometimes doesn't get back to it at all. To get it back to idle I have had to let the clutch out a bit with the brake on. I'm guessing this could be something to do with air screw adjustment but don't really know. Any ideas? Also, the clutch appears as though it might be sticking a bit. When letting it out the bike moves slowly but then gets faster. It never appears to fully engage the gears though as the engine revs never quite relate to the speed, especially when going uphill. Any help with this would be greatly appreciated. Thanks in advance.
