johnyboy
    17
1 Follower
  • Website URL
  • ICQ
3,519 profile views
  1. Hi has anyone had an Rtl250 or Tlr250 cylinder relined? Who can do this?
  2. Colin lees, ty off road
  3. As far as I know you can only work lights if the bike is fitted with twin coils inside the flywheel,most Japanese imports don't have these.the wiring diagram in the manual will show you if you know someone that has one or there was one on one of the honda trials pages
  4. Is it the boss or the lever that is cracked? A tlm260 has the same boss but an alloy lever.I have successfully repaired the one on an 87 rtl which is the same as 88 and 89 bikes John
  5. Have you tried putting some silicone round the edge?this is what I do,seems to work
  6. johnyboy
    Gear Lever
    Hi bash plate The crf 150 definitely has the same shaft size as the yamaha's and the Hondas you've mentioned.i have alloy levers for the crf150 fitted to both rtl250 and TLM 260 Hondas Johnyboy
  7. Could it possibly be the two mounting bolts on the carb manifold have been tightened too much?had similar problem with RTL honda
  8. Vintage Motoworx How much are your pistons going to cost?
  9. Have experienced the exact same problem on an Rtl250,same solution slacken carb nuts
  10. Hi,if you have a tlm250-they were only made in 1988 and1989,from 1990-93 they became the tlm260.i have a manual though not for sale but i can scan the odd page for you
  11. you could try ellastone off road(01889 590186)the y recently brought 70 bultacos plus lots of spares in from the states
  12. hi boywonder what parts are you needing?i have a manual(not for sale)so could help with part numbers.email me on l.mcwhirter847@btinternet.com or pm me on this forum
  13. I HAVE HEARD THIS TOO,I WAS TOLD BETWEEN 60 AND 70 BIKES-A MIXTURE OF TRIALS AND MOTOCROSSERS-SOME VERY NEARLY NEW CONDITION.I THINK IT IS ELLASTONE OFF ROAD THAT`S BOUGHT THEM
  14. has the nipple broken off flush with the caliper?if it is sticking out a little your best bet is to mig weld say an m8 nut over it and screw it out when it is still hot.bleed nipples are available from DAF TRUCKS in M8 thread,again you would need to machine it to fit the tapered seat in your caliper,good luck
  15. ANY BODY GOT PHOTOS OF THE HONDAS AT TELFORD CLASSIC SHOW?
