Hi,
Thanks for the info! I'm thinking about using two base gaskets it should add around .035" to the thickness before squish, have you ever tried this? Should I put a little silicone between the two gaskets? Does the cam chain require less than normal tension if so do you know why? I just got a set of standard rings and I'm sure there're available the part number is 13011-446-811 (same # as XR200).
Thanks!!!
