philswiv
29 -
If they're owt like my '97 ones they'll just fall out if you remove the wheel and give it a good shake ! Mine are that slack!
Aye, it's a round rubber O-ring. I put some new clutch plates in recenly and the seal was a swine to replace. Once set free it seems to have life of its own and doesn't want to return to the darkness of the clutch housing. I think I sould've put a new one in because, A - It wouldn't have been so distorted. B - It now leaks a few drops once the engine is really hot and C - It would have been kind to the old one to grant it it's freedom.
Hi Folks, A bloke asked me the other day if my '97 Techno still had it's fly wheel weights on it. Why wouldn't it have? Is there any point in removing them? If so, why were they put there in the first place? I would imagine that if I was to find 'em and try to remove 'em that they'd be under the right hand side engine cover behind the fly wheel? This would mean I need a fly wheel puller, right? Can anyone shed any light on why/where/what and how on this subject? Cheers, PhilSwiv .
If all else fails - swear very loudly, throw down whatever spanner is in your hand and march to pub. Chew somebodys ear off about how you suffer for your art. Totter back home with a self satisfied "four pint glow" and go to bed. Repeat this process over several nights untill you get the correct pressure at the brake lever ( I still havn't cured my rear brake problem, much to the benefit of the local pub landlord).
Some food for thought there guys, thanks. I'd better hurry up and get out before all that mud dries up I wish, roll on spring!
The wheel bearings are only about
Make sure you take out the swinging arm and the shock absorber linkages. These parts here are on bearings and are moving up and down all the time you ride and the grease in them gets washed out by the rain and, particularly, the jet washer. In fact you can't go far wrong with checking every bearing on the chassis. That's the one's I just mentioned, the headstock that you've already mentioned and the wheels. That should keep you busy !
I've bled and re-bled the rear brake of my '97 Techno. I've posted messages to this effect with the usual "have you stripped it/cleaned it?" well intentioned but obvious answers. I now have the whole system rigged up on my bench. I tried using a different calliper - still no change. I tried a different caliper and a differnt brake hose - still no change. I tried a new master cylinder seal set (
I've gone for the cable tie option on my '97 Techno. The bottom two mounts had no where to bolt into so I have (very neatly) put one cable tie through each of the radiator mounts (bottom left and right) and secured them to their nearest frame rail. Once the excess cable tie is trimmed off and the rad cover is back on it looks very tidy. Cable ties and gaffa tape - the poor mans "Snap-On" tool kit .
Hi Folks, the place where I ride is very muddy at the moment. I, as an off road novice, find the mud very disconcerting. Is there a technique for dealing with mud? Am I doing it right by just (trying) to relax my grip and just constantly correcting the steering as it slews left to right? I tend to let the speed drop right off but I've read about crossers and Paris-Dakar types going faster in these situations to dig in the rear and lift the front out but I have a mental block about trying this particular technique. What sort of tyre pressures should I be running? Bear in mind that I'm just learning/trying and not competing. That lot should keep you busy . Cheers, Swiv.
Thanks honda
Thanks for that guys. Motopat, the only trouble with your suggestion is that there are no old wires to copy from. This bike has just been stalled all it's life to stop it! Bob, I'll have a look for the afore-mentioned wires tomorrow. cheers fellas
Hi folks, I've had no response from the Beta forum so I'll try here instead. My '97 Techno has no cut out switch. I want to fit one or maybe a lanyard switch. I know they only have two wires (having fitted a new one to my lads crosser) but I don't know which wires to chop into on the Beta. Any ideas?
Hi folks, I'm sick of having to stall my '97 Techno to shut it up. I'm wanting to fit a lanyard switch so I don't have to do this and to cut the ignition when I have one of my "close encouters with the earth". I don't want to go butchering the wiring willy-nilly so, which wires/wire do I have to cut into? Cheers.
I struggle with this "beginers" tag. I am a beginer but I feel that other peoples ideas of beginer are probably of a person more skilled at the trials lark than me, or are they? I suppose I should just go watch a club trial and see what the organisers idea of "beginer" is and see if I fit the bill. Nothing is worse for a persons morale than finding themselves out of their depth....no matter if that's in trials or at work, it's a negative thing and very bad for confidence. So, back to the topic - where in Yorkshire might I find a club trial this year that I could see "beginers" in action?
