kev99
30 -
hi all, i have a tx pro 280 04 and can change up gears no prob but it wont change down i can stop the engine some times it works but now it refuses to change down . any ideas? as i am new to this bike cheers kev
Thanks bigfoot the bike is not new i think its 03 but had virtualy no use will try the slow throtle as it just wants to rear up also riding slowly with no clutch its a bit frantic like its an on off switch instead of a throtle cheers for help kev
hi all, just a quick question i have just bought a pro 280 does anyone have a prefrence on quick or slow action throtle i think mine is quick and while i am only learning to trail seams a bit too much any help please Thanks kev
Thanks for reply"s emailed john and he will get back to me ...cheers kev
hi all, does anyone know a decent lace in north west were i can get my ty 175 engine re built all parts seam ok but needs crank seals , any idea of cost ? i just dont have the time to strip it my self cheers kev
pattern mud guards can be found ebay sammy miller ect kev
hi all. hi brucey . i have just done a swing arm lenghten it at the wheel plates as charlie says mine must have been a bantum swing arm because both sides are bent out it takes a 400 very well. and there is 1 on ebay cheers kev
hi all. superhondaman dont want to jump in but i wouldbe intrested in the flyer. kev
hi all, Thanks again charlie as you may have worked out i am a bit of a novice at this game ,but all the help on here is wonderfull so you may have other questions along the way !! hope you dont mind ..kev
hi all. Thanks charie. i did the mod on swing arm length by 1 inch . cut the full spingle adjuster off and had new ones profile cut plus 1 inch to the front this way no need to fill and it thought 1 weld rather than 2 would be stronger { could be wrong} but without the chain tensioner lugs. i drilled and then welded pins for snail cams. do you prefer powder coating or good old paint and laqure? kev
hi squid , cant see no reason that the 125 would not be ok on 40:1 mix but i can be corrected if wrong guys
hi charlie,thankyou for your reply but now i am confused!!!! the 2 swing arms that i have both look like the pic and measure 150mm across the inside back edge. was this a factory part or would someone have kindly widened them for me. will have to dig in the garage and see if i have a striat one. but it looks like i have saved some gas,just slipped it over a 400 back wheel and it looks to have good clearance.. thank you again for your help ... kev
hi charlie, how did you widen the cub swing arm without cutting it was thinking of doing one myself. cheers kev
hi all , 40-1 mix works well on both 175 and 250 ..kev
