Hi, my Techno 250 has developped a fault where it will jump out of 3rd and 4th gear.
I split the engine and had a good look at the gear box and I've identified the gear selector drum as the main culprit.
This is all good and well except I have no idea where I'd be able to get a new one.
As I've split the engine casing I'm going to do a few other things while its in bits on the workbench;
New piston and rings, big and little end bearings, main bearings and seals, selector forks and a full gasket set.
If anyone knows a supplier that can get these parts for '97 techno 250 I'd be really grateful for the contact info.
Hope you can help.
Cheers, Ben.
