Posts posted by grib
After pulling the RH case down with the case screws the crank bearings will feel tight - I use a tubular spacer on the inner race of the RH bearing and gently ease the inner race in using the flywheel nut until it feels free. I have tapped the inner race with a drift & hammer in the past but the spacer & nut works better.
Build it in the left hand case. Put all the bearings and LH seal in the cases first (heat cases to fit bearings), pull the crank in to the LH bearing using the primary drive nut and spacers, slot the gear clusters etc. in and then put the RH case on and pull it down evenly on to the crank with the case screws. Don't hit anything with a hammer, fit the RH seal last.
Pistons are the same as a 240 - not particularly cheap. 241 is a 1986 bike, as you say the frame and forks should be red, I think from memory Ford Rosso red is a good match. The tank would either be red with white decals or white with red & blue decals. I have got a parts list with exploded diagrams of the whole bike, but its a big file, if you pm me your email I can send it.
The tanks on these bikes were painted when new. I had a 301 about 15 years ago and re sprayed the tank and put on new decals with no issues. I would have thought that if you have problems with bubbling paint then it is probably caused by whatever paint has been put over the original (in the last 30 years). I would rub the tank down to the last layer of original paint and start from there.
240 engine rebuild
in Fantic
There has never been workshop manuals for Fantic trials bikes. There is a parts list which shows exploded views of the whole bike, and there is the handbook that came with the bikes when new which has some specs for torques etc., both of these are attached to this post. The 240 is a fairly straightforward engine to work on, its the first one I ever rebuilt without a manual, and common sense should see you through it. It probably helps if you have built engines before and already have an idea of what goes where, just remember - if you are having to apply a lot of force to anything to get it to fit, something is probably not right. I have done lots of Fantic engines and am happy to answer any queries.
Fantic 240 OM.PDF
Fantic 240 PM.PDF
