bul159
    3
  1. Thanks matt, It will be faster for you to give me the dimensions of the tank (from the mounting holes to bottom,the inner "tube" dimension etc..),and I will look then on my frame. Thanks a lot!!
  2. Hello everyone, This post makes me think of something I've always wondered : is possible to mount a campeon tank on a 159 frame? I was looking for a second tank (just in case) and I find the campeon kit really great looking. Thanks a lot
  3. hello everyone,I will try to be clear (my english is not so good). I have a brand new pre jetted mikuni vm26,needle clip is in 2nd position,new ignition stator(wich comes from a 175 lobito,I believe they are the same but is it ok?) 2.4mm advance timing.new piston rings ( stock bore). The bike doesnt run fine and has no power in low rpm in the first 1/4 of throttle.(a bit like a motocross).idle seems to be good,bike starts good 2nd or 1st kick. I would like to know what are the measurements/size of the intake manifold for a 199 (cylinder side not carb side),and what could be the cause of a bad reving. Thanks a lot for your answer.
