rev4t
    10
  • MSN
    scorpa.andy@live.co.uk
  • Website URL
  • ICQ
1,618 profile views
  1. Hi guys , just replacing the kickstart assembly on my vertigo vertical, and can't get the kickstart to return, do I need to take the clutch off for re assembly, did it about 2 yrs ago but can't remember what I did
  2. rev4t
    Service manual?
    Hi I need torque settings for 2019 vertigo vertigal r as just fitted a low comp insert,, can anyone please help
  3. Hi just fitting a low comp head insert, anyone know the head bolt torque settings please
  4. When fitting a hope bulb hub with disc, what rim and spoke are needed
  5. Thanks very much, it also looks like that I might need a stepped rubber to manifold, according to in motion website, so will order one of those, I used the straight one from the 159 to try it,,,, would that make much difference
  6. Hi triasrfun, I have a 159 sherpa, I had a carb built to your above spec and bike runs spot on,,,, I have a 78 350 too, rebuilt to 340 cc, carb is lean on bottem end with these settings, shall I just richen it up with bigger pilot jet, or does this bike need all different settings, ps is Bob on on power, thanks
  7. hi im currently building a trials outfit. also ride solo. live in wigan . andy
  8. rev4t
    Rev 4t
    not tried clening out exhaust. but would this be making bike bad to start etc
  9. can anybody help . i have a rev4t 08 . thats bad to start, fouling plug up , and struggles to rev clean. i have .......... re jetted carb,re set valves, had stator re wound, thouroughly cleaned out all carb and choke jets,new plugs, clean air filter, altered air screw , breather pipes clean
