When do you guys stop doing this?
I'm 80 now got cancer. Been treated for the last 3 1/2 years I still ride if I don't ride I observe I still love it sometimes I finish sometimes I don't but I allways enjoy it exhausted or not
Strange but true
What I did with my stator cover I drilled a hole in the outer part of the crankcase tuned up a spigot the right size for a plastic pipe and glued it in with arldite sealed the stator and had never had corrosion inside in two years
What Is A Twinshock ?
Could'nt have said it better myself ?
Smoking Cub help
Hi Bruce my Morgo oil pump has ball and springs in the crankcase
How Do You Change A Tyre?
But then your dads a real trials rider old school ?
Tiger Cub Modified Gearbox Cover
Thanks Brucey hope to see you at a sidcup trial some time
I like what you have achieved nice bit of work but I still prefer the early distributor outer case on but I will do the oil seal mod on the kickstarter shaft thanks for sharing your work and ideas
349 - water inside magneto casing
It might not be water getting in but condensation not getting out we used to put a breather on top of the casing with rubber tube routed higher up the frame use to stop moisture getting between the points
I prefer it with the cover on easy to keep clean and a bit of protection still good luck to you
- Triumph Cub oil filter
Jon could you tell me the size of the hose on your filter thanks
Gone 4 stroke
If you get a long screwdriver and going down the right hand side of the engine you can get the blade on the end of the header pipe had tap it loose it doesn't take much and it's thicker metal on the end of the pipe
Gone 4 stroke
Up is on when engine running down is on all the time you need to put it down if you haven't started it for a while just to top the carb up phut phut is normal lovely aren't they enjoy
Will it fit?
Bike fits ok in a berlingo
pete kirby belt driven clutch
I run mine without the dished spacer and it's no problem and light lever
