Pro Water Pump
mintsauce
Hello all :)
I have a 2004 gas gas 280 pro and have taken the water pump off so that i can replace the seals in the clutch. Can someone tell me the best way of alligning the pin in the pump shaft with the slot on the drive gear, i can no longer stand the stress of trying to locate it :beer: I have also noticed that when you wiggle the shaft water drips out. Is this normal? I have probably got water in engine now thinking about it :D
I have got to renew the bottom gasket on the barrel any advice on things to be careful about?
Thank You :)
Put the main cluch cover on and slowly push the kickstart down with a little preasure on the pump housing and on it goes but make sure you get in to the right 2 slots!! :)
:) What do you mean the right 2 slots! Is there more :D
Will try again tomorrow when my patience level gets back to normal :beer:
