Hard To Start Running Rough Rev3
leggins
My rev 250 has been causing me unwanted headaches. The last couple of times out I have had a hell of a job getting it started from cold. When it dose start it coughs and pops like a good un. The plug has been oiled up when removed. I am using a mix of 100 cc to 5L is this too rich ? When I replace the plug with a new one it seems to do the trick for a short while then its back to square one . My main concern is when the bike is ticking over it pops constantly unlike other rev 3s Ive listened too...... Any ideas ? :D
p.s I have done the carb mods on r2w ,s site
My 06 rev3 is a complete b--tard to start when cold takes about 20 kicks then
it fires up likes it flooded I HAVE ALSO DONE CARB DRILLING MODS and keep trying spark plugs and i run at a mix of 70.1 any one else havin same bother!
What a shower.....
Bit of choke, ONE kick, on 70:1 with Silky 2t.....piece of pi$$...though not in with the petrol obviously.
Seriously when I got it I put a new plug in and blew through the carb before I kicked it over cos the guy I got it from had problems too. ....maybe it's weight behind the kick.... :D
like the new avatar Barry, (ps she won't let me buy superflous spares........sorry mate)
Edited by Slapshot 3
That might be because it is (flooded). I had exactly the same problem on my old bike and tried everything to cure it (carb, electrics etc. etc.) to no avail. Then, when I took the engine out to be rebuilt I noticed fuel dripping constantly dripping from the hose, even with the fuel tap off. A seal inside the tap was buggered... you can see where this is going. One quick call to Lampkins to order a new tap and the problem was sorted!
Was that aimed at me? if so I get the avatar bit but not the spares?
yup,
pm'd you about the hub last week, she found out and I got grief....again!!
Mine started 1st kick last week after being stood for over 3 months! I use 75ml of 'PJ1 Silverfire' oil per 5 litres of ordinary (stale?) unleaded petrol.
Turn fuel tap on, choke on, one full turn of the throttle and kick it with a smidge of open throttle :D
